P1000 Wiring multiple rocker switches and volt meter.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
But I worry with all accessories you may find your self with a dead battery! This can be avoided by isolating all added accessories but would require an additional battery. Just my two cents;) Kits are available in the store here on the forum.
Micah_Deshotel
Micah_Deshotel
42
217
Egan, Louisiana
  2. Talon X LV
Appreciate all the helpful diagrams. Just about to do some similar wiring.
Reactions: bigr244
63,988
I would consider a relay for both light bars.
Dome, usb, volt, winch, I personally would not.
Second battery reloves around how clumsy you are to leave something on without the machine running.
Reactions: bigr244
Eltobgi
Eltobgi
4,599
15,186
North Dakota
5F05A1BB CFA9 44D2 A5D6 B291299CDBAA
I purchased these and cut off the push button switch and fuse holder. Wired the power and ground to blue seas fuse block and used the fuse also in my blue seas fuse block and the switch wire to the power out on rockers. Just noticed the picture is actually 40 amp but the price is right, lol.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I think second or auxiliary batteries are more than that! I don’t like the idea of straining an electrical system with mods which create heavy draws on the system depriving it of needed power. Aux battery with isolators prevent any such draw. To take it further...with my set up I can combine batteries for increases power during winching. So....it’s not about being clumsy it about safety;)
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Thoughts on these?
Sent from my SM-G935V using Tapatalk
They will work just fine. Depending on where you will mount your accessories it may not be the cheapest route as you run + and - accessory wires to relays. Ex. Would be rear lights mounted on upper cage would require a long run of wire to under the hood relays.
Reactions: bigr244
bigr244
bigr244
136
194
US
Eltobgi,
I am getting closer to starting my install. I haven't purchased any relays yet; if you have a better suggestion please let me know. Thank you.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Eltobgi,
The relay you posted will work just fine. My personal preference was to use the relay with shielded wires to run to accessories. It looks cleaner and just made sense for my install. However most are not as insane as I am with electrical. Lol
bigr244
bigr244
136
194
US
How am I doing! 9bc8bd3d1e697aff8baf7b344ba281af
Reactions: TripleB
63,988
Step 1 done.
Once you get the red line ran, you can test that all the switches light up with a 9V battery.
Hook up the black and red lines should do it.
Reactions: TripleB and bigr244
bigr244
bigr244
136
194
US
Everything lit up thank God! This was fun. So my relays deliver tomorrow. What's the next step? Mount my blue seas fuse block?D5acb2b1c187c4bea33d5edd3b1bc802
63,988
Yes and relays since you chose relay control design.
Note for other readers. Or if you do this again.
You didnt need to use such thick wire. 18g would be fine. The whole panel (set to relay control) most likley want even come close to an amp of draw.
Now the relay primarys should be larger depending on the accessory.
The relay control can be small guage.
Ok. Good luck.
Reactions: TripleB
