P500 Wondering if anyone knows this cause/fix
colorblindclown
colorblindclown
16
51
Iowa
Noticed I had some oil around my axle at the front diff. Just wanted to see if anyone knew the issue or if I just need to start turning bolts and find out when its open.
20200724 160221
lee
lee
Village Idiot
2,386
13,516
Springfield Ohio
It looks like Oil is getting past the seal.
there are two probable potential causes.
1 The vent is plugged and as the diff warms up it pushes oil past the seal. This can be checked by removing the vent hose at the diff and seeing if you can blow threw the hose.
2 The seal is leaking. Probable cause is an assembly issue like it’s installed crooked or it has pushed out from where it’s supposed to be. More difficult to check, it needs some disassembly to check.
Reactions: Lburou and trigger
Backwoods
Backwoods
35,221
357,675
Douglasville ga
I had a brand new Yamaha do that the day I brought it home . I tapped the seal back and and it never leaked again.
colorblindclown
colorblindclown
16
51
Iowa
Ok thanks for the words of wisdom.
colorblindclown
colorblindclown
16
51
Iowa
Did you just have to pull the axel to do that or did it require more take down?
