P700 Won't run over 30 mph
Catfish
10
Oklahoma
Mine did same thing had to replace spark Arester an weld it back . It should rattle while idleing if weld is broke....
A
Arnulfo
Tomball Texas
Same problem with mine , but only gets to 15 mph. I have removed air filter and muffler and ran without with no change.
Yours sounds like a transmission problem, lack of oil pressure or clutch problems. Seems to not be shifting out of 1st, that's usually the speed 1st tops out at. Or the cam lobes have wiped, but they usually pull a little more speed, their just lazy to get there and won't rev up properly.
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
What year?
Do the new 700's have the same seat belt limiter like most machines? Might try buckling the belt if you aren't...
That's a good point
41,838
Looking at @Arnulfo's other posts, he has a 2014, so no dice on the belt.
P
Pete
15
9
Did you discover your problem? Mine is behaving very similarly.
