WTH was Chevy thinking??
I agree I liked the 18 back to a 15 I believe it was.
Saw this fiat today at sheetz, not sure the year but it cant be more than 5 years I wouldnt think and the rockers on both sides were shot!
That Ram shouldn’t be rusting already. I’ve seen plenty of pics of that to believe it’s a problem. It’s so weird because locally we have more problems with aluminum corrosion. It’s gotta be specific regions where a vehicle is from to determine what effects it.
We do get plenty of snow here and they use a lot of road salt so I’d assume we’d have more issues but don’t see much for newer stuff rusting. Occasionally older stuff including Toyota and many of the trucks that get pulled down from Canada are bad but that’s about it. None of my trucks have ever had issues. Last one was from the coast, Seattle. From what I’ve seen it looks like trucks that do have a problem aren’t washed properly and get a buildup of dirt and mud that holds moisture.
ehart814
ehart814
1,701
3,889
NWPA
That body style started in 2009. Mine is a 16. I know a guy in my town that has one of the early (2009 ish) of those trucks and it's in much worse shape than the one you saw. Here in northwest PA you better wash em, and you better undercoat or you're not going to get more than 5 years before you're rotted. Doesn't matter what brand youre driving.
Mopower58
Mopower58
TRUMP 2028
88,421
756,482
Crystal Springs,Ms.
Our friends from Kentucky always go through a car wash after driving on icy roads because of the salt accumulation.
G
GWH
749
2,476
Las Vegas Nevads
Allison is electronic. Why kill a fully mechanical truck with something that needs a computer and a ton of electronics? I know I think different then some but that’s my thought
I like the way u think!you should build it.Theres a lot of preppers that would pay u a lot for a vehicle that will survive the big magnetic electronics killing event.Im just stocking up on beer and wishing I still had my 1970 c10.
I’m kinda old school.Like building stuff like that. Big fan of old mechanical diesels. Our camping rigs don’t need a single wire, even to start. All old crap to most anyone else but I like um
Favorite bodystyle of all time is that GM you speak of. Never had the pleasure of owning or building one. You got a picture?
G
GWH
749
2,476
Las Vegas Nevads
I’ll look it was actually a k 10 long bed that my dad bought,that I bought from him.He was so proud of that truck; it was brand new and he was working as a mechanic in a gas station garage bring up four sons.If I find a picture it won’t be a glory shot of the truck. It well probably a picture of the truck on a hunt or fishing picture .
Gorms
Gorms
110
448
Mass
I like the amenities of newer trucks but there is something about a vehicle that runs without any electrical control. I feel more connected driving them, and having the ability to work on them with common tools most times.
Fleet of '11-'15 6.7 F450 superduties, about 20 trucks, at work and we have lost 2 motors from dropped valves or broken glow plugs, a few tows home a year, and plenty of emissions/check engine problems. Not one truck has 100k on it yet.
That's why I cant get rid of our 98 Dodge 2500, 5.9 cummins (12V) 5 speed. It has worked itself towards a frame transplant, coming this fall if I get time. Will add a turbo and a few extra clutch plates while I'm at it. But it has always made it home, even after some abuse.
Screenshot 20190911 223252 Photos
Not sure what the check engine light even means on a 12valve. Only requires fuel so I figure it’s just a dummy light left in the dash from the gasser lol.
Air heating element on intake maybe!?!????
I was actually kinda kidding. But the truth is the only thing that I’ve ever heard of that it could be is alternator. There’s just nothing needed other then fuel and that’s not electronic either
VaHillbilly
VaHillbilly
NTC immigrant gardner
5,864
51,201
Sw VA
Ok I knew it was new by my standards anyway. it had that sloped backwards front like a kid with buck teeth & an overbite! Made me wana stop n put some braces on the grille!
VaHillbilly
VaHillbilly
5,864
51,201
Sw VA
I believe your right different areas have different problems and different cars rot faster! Around here fiat are by far the worst but Toyota tries like hell to catch em! With 1st &2nd gen tacomas being the worst! U dont see them anymore bc the frame broke or Toyota bought em back, you see fiats less than a decade with rust bubbles over the rear wheels all the time idk what it is. BUt makes me think cheap thin metal and that's why they cost less . Idk tho nobody does for sure but they will argue til they are blue in the face
VaHillbilly
VaHillbilly
5,864
51,201
Sw VA
Looks like more than a pickup truck!
Sounds like alot of good aftermarket ideas went into this design, seems like they thought about the mechanics for once but the wont win over any Ford guys for ease of maintenance hell they use to pulling the cab to change the oil! Or replace a turbo every 80k miles or fix broke rocker arms once per year. :D:D
I think a lot of the rust that some rigs suffer from is from clogged up drain holes and dirt sitting on the backside of things.
If you compare some trucks that have been in the same area all thier life, one has waisted doors and boxsides the one next to it is perfect. My ‘98 Cummins 400k miles lived its life here in Spokane with heavy snow and deicer never garaged, never had rust. I know of plenty that have. Some body styles it’s how it was washed. I think some are worse then others for having bad designs where dirt can collect and be hard to clean out.
As far as cars having s***ty metal, yes there are different qualities of steel but regardless of what people think steel has continued to get much better quality since the ol cars people refer to, more rust resistance and stronger however it is thinner.
