Talon WTX Talon R
Not really anything. We used to have some nice sand dunes 10 miles up the road, but it got shut down and they are selling the sand for fracking.
We usually go ride at my friend's ranch which is 6 hrs away.
In a few days we're going to the Guadalupe mountains in NM to ride the forest service roads. I've never been, so I don't really know what to expect. It's about 150 mi.
Sent from my SM-G975U using Tapatalk
That sounds great, New Mexico is awesome. I’ve got a place north of there, 140 acres with a back gate right into the Santa Fe National forest. You’re welcome to come ride if you’d ever like. 👍😊
WTXoffroader
WTXoffroader
36
102
Kermit, TX
I added a stereo a little while back and I forgot to post it.
I ordered the PBR stereo mount with 2 switch holes originally. The hole for the radio was too low and would have required cutting the plastic to make it fit. The bezel on the radio was also too fat for the switches to fit, so I made my own. I still don't think the switches will fit, so I will need to find another place for them or use a different style.
I will likely paint it black so it doesn't stand out so much.
Ad3cb00faeb6634590a28414e5d93bd9
I put the speakers behind the seats. They are kind of hacked in, but it works and they are kind of hidden. Someday I may buy a new panel and try again.
The sound is pretty good, but the wind and engine drown them out at higher speeds. I plan to add another pair to the kick panels along with an amp. The speakers have a lot more capacity than the head unit can put out.
179db52a0bf76fe5e5de424b99810d50
I also added a pair of siezmik mirrors.
46115d3d9a657fcdf5366f4dff0bc2fa
WTXoffroader
WTXoffroader
36
102
Kermit, TX
A couple weeks ago I adjusted the wheel alignment. The steering wheel wasn't centered and the factory adjustment had about three inches of toe in.
I adjusted it to about 1/8" and it handles much better and the steering is more responsive.
This weekend I adjusted the valves and did the first oil change. Before the clutch seemed to have some lag before engaging. Now it seems to grab a lot sooner.
I'm ready to get it back out on another ride.
Lil_Steve
Lil_Steve
544
2,107
Gilbert, AZ
Did it require adjustment already at the first oil change or were they in spec?
WTXoffroader
WTXoffroader
36
102
Kermit, TX
After our last ride it started rattling a little bit. The exhaust valves were definitely out of spec. I tightened them up and all seems good now. The intake valves were fine.
My wife's x4 still sounds fine. I probably won't mess with it unless it gets noisy.
Reactions: Lil_Steve
WTXoffroader
WTXoffroader
36
102
Kermit, TX
Got some new Fuel wheels for father's day.
7e72a9a8fe59698abf41781ed0e54031
I also installed some STV harnesses about a month ago.
20200524 160720
WTXoffroader
WTXoffroader
36
102
Kermit, TX
I've used it twice for a couple short pulls and it worked fine. Install was ok.
Reactions: jroot327
