P1000 Post your homemade mods!
ghost
ghost
993
1,873
BC
These are the mods I have built for my 1000.
Thanks for that - I can see what you did with rear rack now.
I was almost gonna get one of these but yours is much better.
8265134
I have a welder which I have hardly used. I'll add this to the project list.
BIGRACK
BIGRACK
202
376
Dayton Tenn
I used 3/4`` tubing 14 gauge on rear 16 gauge 3/4`` on front rack. Rear bumper is 1 3/4`` OD tubing 14 gauge wall thickness I will get a close up pic of tab on hitch to bolt knee brace to.Used 3/8 bolts on rear assembly. Rear rack is 15 1/2`` inches inside by 43 inches outside that way it fit between tail lights.20 quart Pelican cooler will fit insde.
BIGRACK
BIGRACK
202
376
Dayton Tenn
Rock Sliders came in very handy at windrock sat. I live 53 miles from WindRock.
BIGRACK
BIGRACK
202
376
Dayton Tenn
I've done some very simple mods.
First is the limb risers
D778c9c92e8f708c83e31a15b73a7a4e
Next is the switch plate
B23fe94600825620699611dfdfeae38c
Here is my mod to the MudBuster fender flares
A59b215d1d97c68e0a13f23841505921
Ordered some mud busters yesterday where I hunt lot of cow manure these will be a big help
Reactions: joeymt33
Stimey58
Stimey58
81
Columbus, Ohio
I used this for hitch rattle....works well, cheap and you can use it on trailers, etc...
StowAway Cargo Carriers Hitch Tightener
List Price: $25.00
Price: $18.50 Free Shipping for Prime Members
You Save: $6.50 (26%)
Note: Available at a lower price from other sellers, potentially without free Prime shipping.
In Stock.
Want it tomorrow, March 9? Order within 6 hrs 20 mins and choose One-Day Shipping at checkout. Details
Sold by PacRec Products and Fulfilled by Amazon.
  • Prevents hitch wobble for hitch racks, bike racks and trailer ball mounts
  • Easy installation - fits 2" and 1.25" hitches
  • Heavy duty stainless steel U-bolt and powder coated plate
  • Will work with most hitch racks, hitch boxes and trailer ball mounts
  • Made in USA
DTAGG
DTAGG
166
237
ST GEORGE UTAH/ACCORD LAKES SEVIER COUNTY UTAH
Had a similar thread to this over on the polaris forums. As expensive as factory parts can be I want to see your home built add ons! Post away!
other than the factory accessories that everyone has mentioned already, i came up with a dust and heat buster that helps alot from under the bencj seat see pic. i used the insulation roll bubble wrap from home depot and cut a section to fit.
0307161828
0307161828a
Johnny_C
Johnny_C
303
143
Western N. Carolina
I will probably add the same type of insulation
for summer driving to our P1K3. The engine
heat was kind of nice this past weekend. It
was upper 40's to mid 50's while we were riding.
But the main thing I wanted to say is I suggest
you test burn a small piece of what you used.
I used some from Lowes in my plane, but it
had a pretty significant burn rate, so I pulled
most of it out!
FYI!
John
other than the factory accessories that everyone has mentioned already, i came up with a dust and heat buster that helps alot from under the bencj seat see pic. i used the insulation roll bubble wrap from home depot and cut a section to fit. View attachment 11502 View attachment 11503
Reactions: pct
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
What kind of heat insulation did this provide? Could you easily tell the difference?
Johnny_C
Johnny_C
303
143
Western N. Carolina
I want DTAGG to respond, but I
talked to a guy in Pioneer TN, that
made the same thing, of the same
material type, but for a Polaris,
and he said it worked well. No
reason that it won't work for us.
John
dale5740
dale5740
886
417
mt airy md
where is your phone mounted 2? and is that ram mount? nice
DTAGG
DTAGG
166
237
it provided more of a dust barrier seal to the seat bottom. i noticed it less noisy and i don't get the heat from behind the legs anymore. i still get heat in the center area of the seat back but as you mentioned it is nice when it is chilly. i have not noticed any melting as it doesn't get hot enough where it is.
I think it's a "slip grip" iPhone mount. There is a screw under the dash holding the OEM switch panel, so I removed the suction cup and drill thru the plastic and reused the screw to mount it. It is very sturdy, it doesn't twist or vibrate. So far, I'm happy with it.
dale5740
dale5740
886
417
mt airy md
good idea that would work great for me cause with radio in dash not enough room for phone!! thanks
ofrcboy
ofrcboy
501
572
Oregon
great Idea!! up close does it look good as well? what kind of paint did u use and how did u apply it? Nice
Cleaned wiped down with thinner and sponge painted with rus-toleum. Very happy with results.
