P1000 2-piece Poly Windshield - REPLACEMENT PARTS - Pioneer 1000
63,540
Replacement Parts List: 2 Piece Poly Windscreen
Part Numbers 0SR71-HL4-A00 & 0SR72-HL4-100
See attached.
Other parts here --> P1000 - Accessory Replacement Parts Listing - Hard Parts!
age?arib=&arim=&aria=&zoom=3&path=%2Fimage%2FHOM%2Fe42db814-8bfc-4943-b0f4-d52d16bad631%2FMedium.png
3 - Part # 0SR85-HL4-101R1 CAMLOCK CLAMP 45MM $13.50 $12.00
4 - Part # 0SR71-HL4-A00R8 HINGE BRKT, W/S $18.25 $16.47
5 - Part # 0SR71-HL4-A00R12 CTR SUPPRT/COLLAR $17.95 $16.33
6 - Part # 0SU95-HL4-10R21 6 X 16 mm Screw
7 - Part # 0SU95-HL4-10R7 6X20MM BHCS $12.95 $11.60
8 - Part # 0SU95-HL4-10R11 BOLT (6X25MM) $14.39 $12.47
9 - Part # 0SU95-HL4-10R8 6X30MM BHCS $13.95 $12.33
10 - Part # 0SR72-HL3-100R3 HINGE SWING ARM,L $10.34
11 - Part # 0SR72-HL3-100R4 HINGE SWING ARM,R $10.34
12 - Part # 0SR71-HL4-A00R10 GSKT, L 2PC W/S $15.95 $14.33
13 - Part # 0SR71-HL4-A00R11 GSKT, R 2PC W/S $15.95 $14.33
14 - Part # 0SR71-HL4-A00R3 HINGE CLAMP 45MM $9.08
15 - Part # 0SR85-HL4-101R4 6MM NYLOCK NUT $12.75 $11.74
16 - Part # 0SU95-HL4-10R3 6MM FLAT WASHER $12.95 $11.67
17 - Part # 0SR71-HL4-A00R5 SCREEN LOCK LEVER $25.95 $23.33
18 - N/A
19 - N/A
20 - Part # 0SR71-HL4-A00R5 SCREEN LOCK LEVER $25.95 $23.33
21 - Part # 0SU95-HL4-10R20 TRIM CLIP, DOOR $14.50 $13.19
22 - Part # 0SR71-HL4-A00R9 2PC W/S DART/NUT KIT $13.25 $12.00
23 - Part # 0SR71-HL4-A00R9 2PC W/S DART/NUT KIT $13.25 $12.00
24 - Part # 0SR71-HL4-A00R5 SCREEN LOCK LEVER $25.95 $23.33
25 - Part # 0SR71-HL4-A00R12 CTR SUPPRT/COLLAR $17.95 $16.33
26 - Part # 0SR71-HL4-A00R5 SCREEN LOCK LEVER $25.95 $23.33
28 - Part # 0SR71-HL4-A00R7 SCREEN WEATHERSTRIP $57.95 $53.26
29 - Part # 0SR71-HL4-A00R6 2PC LOW W/S WTHRSTRP $17.95 $16.67
- - Part # 0SR71-HL4-A00CK1 HL4 2PC HDW KIT $154.95 $132.92
- - Part # 0SR71-HL4-A00R12 CTR SUPPRT/COLLAR $17.95 $16.33
- - Part # 0SR71-HL4-A00R3 HINGE CLAMP 45MM $9.08
- - Part # 0SR71-HL4-A00R9 2PC W/S DART/NUT KIT $13.25 $12.00
  • 2 Piece Windscreen.pdf
ProudDadOf5
ProudDadOf5
3,113
24,131
Winfield, WV
  2. Other Brand
Hey @Hondasxs,
I have the installation instructions for the windshield as well if you would like me to post the pdf..
Ohio4x4
Ohio4x4
I brought the dishwasher
1,494
15,019
Anyone have the part number for 18 Flange Collar(Top Hat Collar)?
I lost mine in my driveway when installing. I made a spacer from a piece of brake or fuel line and used a separate washer. I later found a similar part at a local hardware dealer. Hope it helps my dealers had nothing for me.
F
FredReid
15
37
South Carolina
Thanks
CrazyHorse74
6
Does anyone know the part numbers for the newer style 2 piece Pioneer windshield? It has a different mounting/opening style that is much better. I would like to swap out the old parts for the new ones. Looking for numbers 3, 4, 6, 19, and 20 in particular. Or just 19 and 20 would work too.
Windshield
DDGrouser
DDGrouser
24
54
Other
Any idea on replacement weather stripping. Lost one of the small pieces the first time I trailered it.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
Before I saw the upgrades on the new windshields, I bought a set of different extenders from PBR products. I haven't really run them much last summer because we just ended up pulling off the upper section but I think we should really like them this spring. One thing we had trouble with was the bushings they send and the factory ones. We watched their Youtube video on the install but ended up moving them around to get everything to line up. Might be worth a try.
CrazyHorse74
6
I got a set of these (PBR Products) for Christmas and hate them. They are junk in my opinion. The tolerances are ridiculous on them. The slot is too big, the hole is too big, the hole is too close to the slot. Etc. etc. See attached pics. I am going to use them as a pattern to cut out a set of my own with my plasma cutter. I will make the slot narrower and move the hole. I just thought if I could get the newer mounting hardware that it would be easier. I sent them a PM on Facebook and no reply. I commented on one of their posts about it and they deleted my comment and then blocked me from commenting. So as far as I am concerned, I will never do business with them again and will never recommend them to anyone. Poor workmanship and very poor customer service!!!
Image from iOS 3 Image from iOS 2 Image from iOS 1 Image from iOS
105,270
bumperm
bumperm
1,848
6,641
Gardnerville, NV
I got a set of these for Christmas and hate them. They are junk in my opinion. The tolerances are ridiculous on them. The slot is too big, the hole is too big, the hole is too close to the slot. Etc. etc. See attached pics. I am going to use them as a pattern to cut out a set of my own with my plasma cutter. I will make the slot narrower and move the hole. I just thought if I could get the newer mounting hardware that it would be easier. I sent them a PM on Facebook and no reply. I commented on one of their posts about it and they deleted my comment and then blocked me from commenting. So as far as I am concerned, I will never do business with them again and will never recommend them to anyone. Poor workmanship and very poor customer service!!!
View attachment 312352 View attachment 312353 View attachment 312354 View attachment 312355
Would be helpful if you mentioned the source of the poorly made and ill fitting parts.
bumperm
bumperm
1,848
6,641
Gardnerville, NV
PBR products. I edited the post to add that.
I had a similar experience. Would never buy from PBR products again. Their ad on eBay said fits all P1000. It didn't fit the OEM windshield that came on my '21 SE. Ater I returned it, they changed their ad and refunded all but $7 and change (shipping). I explained it wasn't my fault their ad was wrong, but they refused to refund the balance. Crappy business practice.
Oh, and the cutting on the steel parts was sloppy and rough, needed to bush the holes smaller etc.
RooseveltRd
Definitely an old post, but did anyone find the related part numbers for each of these hardware components?
RooseveltRd
See attached.
18 - N/A
19 - N/A
Any chance you have the following for the new style 2-piece poly windshield (0SR71-HL4-A10 & 0SR71-HL4-A20)? I need to get some of the hardware pieces due to buying a used one with some missing items. (Dumb mistake on my part!)
K
kellen20
7
Anyone know if or where you can order just the upper windscreen? I cracked mine pretty bad and need to replace it.
Thanks!
Scoop
Scoop
4,215
15,755
  3. Talon R LV
If we get enough people together who need parts, you all can just by a new windshield and divvy everything out!
