P1000 2022 “Duck Truck”
JenElio
JenElio
64,274
602,962
Loxahatchee, florida
that fan is slick....I'm trying to use the 4" bilge fan and using a strap across the top won't allow the center cover to fit.....We rode 36 miles yesterday and seat got warm but not HOT.....I plan on getting a @trigger shield at TO and hopefully someone can get me a bracket to fit....Thanks for your pics....
Lots of different ways to mount the under seat fan mod. I used a spare winch mount I had laying around. Fits perfect and aimed it straight at the headers, blows all the hot air out the rear passenger side wheel well 👍
20201113 204740
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
That looks slick as well but these top covers on the '22 models won't allow for anything 1" or wider on either side of the round bar up top....I want the fan for the just in case scenario lol
duratime
72
191
Monterey,CA
With the three large switches (only rated at 3 amps) I decided to run some smaller items. Rock lights are on one and I split my dome strips one for each of the other switches. Works pretty good for what I wanted.
I know you have more switches now than a 747, but you could have used those 3 factory switches to power a relay and have load side of the relay use your AUX battery. Great work so far BTW. I'm eagerly waiting for my Green Deluxe. Also, are you happy with the Rough Country bed mat?
kandt
kandt
126
762
Bluegrass state
Thank you.
First about the switches- there are far more people on the site that can answer and explain your question. I would assume you can do what you are asking. The switches are only rated at 3 amps, but going to the relay should be ok to let it do all the work. @Hondasxs can help you with that question.
I am really pleased with the Rough Country mat. It is a quality product and has the lipped edges to hold things in the mat. My only problem with it is that it and bed extender do not like each other. I may have to trim the raised lip on the ends back by the tailgate to allow the tailgate to close easier. Not much pressure now closing it, but a little resistance it there. Other than that, yes it is a good product. I would recommend it.
PJon
PJon
760
3,055
Arizona
V2 Viper Winch 6000- awesome looking winch. It took some time to get nuts threaded on u-bolts by myself but it got done😤. Would have been much easier with another person to help. Even though I struggled a bit, this thing is awesome. No problems with fit. Looking at the Trail Model, the deluxe did not have the side plates (or mine didn’t 😜) that cover the winch. I had plenty of room, no fit issues. Just as @Hondasxs described in the earlier posts, you have to get the top of the mounting plate under the tab of the frame when installing.
I did not wire it at the time of mounting to the Pioneer. I did all my wiring at one time.
View attachment 336660 View attachment 336662 View attachment 336663 View attachment 336664
Just noticed your winch mounting. I realize that the front bumper on the ‘22’s may be different, but on my ‘18 they recommended flipping the winch over so that it winds in from the top. Much better angle on the rope.
kandt
kandt
126
762
Bluegrass state
Yeah that was what the instructions said but was for the elite. @Hondasxs recommended mounting it the way it is mounted.
63,543
When installed opposite, it does not clear the cross member. The cross member is not made to handle any pressure. It will snap into being cast aluminum.
I guess I need to get some pics of this and add to my install thread sometime.
kandt
kandt
126
762
Bluegrass state
Hope everyone has safe travels and a great time at Takeover.
Been working on the “Duck Truck” a little. Lol
Nothing major. Crossroads 3D sent some test panels and been messing around with them. Not the finished product but gives an idea on the look. I just riveted it in place but plan to use push pins or nutserts to fasten it for the long haul.
I used the paint marker for the gear selections as well. Thought about finding the glow paint marker, but this was easier to locate and does what I need it to do.
Also, I had a ton of cool stickers and was looking for a place to put them. Not fond of a ton on the outside so decided to start placing them under the hood.
I did find a place outside for a special sticker @Hondasxs (trying to get more speed or horsepower, which ever it provides) 😂😂😂😂
2C2DF165 6DB9 4334 A405 ED9D938CC4B5 6962E91E 7C98 4E4B 9F09 7454ACE2E57E 32CA0698 6B00 4DDE 8BDF 1969498113CF 3EA74583 B1A8 4B55 8712 7C97EC541503 09F6965B 6629 4A38 B322 BDD8AAF13EA5
kandt
kandt
126
762
Bluegrass state
With the 2022 models- the extra ground cable is not present. I didn’t want to ground to the main battery so I added a ground cable to the frame. Removed paint, drilled, bolted cable to frame, and added dielectric grease after bolting cable to frame. So far all components look good. Tests showed same numbers compared to main battery ground. I failed to get a picture of the ground addition.
Also added a couple of battery tender ports to plug her up when not using much and during the winter months. I ended up putting them in the glove box. Out of the way and easy access while being able to charge both batteries from the same side of the machine.
3967E976 D93D 4BC7 BCCB F41A380EB322
kandt
kandt
126
762
Bluegrass state
Gun rack
First I don’t have the skills several here have for fabrication and welding. I do neither. But had some stuff laying around that I thought would be usable for a gun rack.
I needed extra space for duck hunting so a gun rack would be ideal to hold 4+ guns.
I had an old 4-wheel cart from TSC that was on its last leg. I used the side and end rails to make the frame for the rack.
Used Honda quick clamps for securing to the rear uprights Everything is bolted together (due to my limited skills). For the holders I first used the “J” shaped gun mounts but punted and ended up using the 7 in wall hangers from Lowes for the gun supports. Two eye-bolts on the back with bungee straps to secure it.
If they are catching too much mud I plan to get a small tarp to wrap them for the trips. Still going to get another coat of paint to cover the new hardware. At first I planned to have upright supports but decided to go a different direction. The “J” mounts can be seen in the earlier design pics below.
B8E24AC3 6684 4DA7 B27A 47EAE9E7BFA4 2613CA36 FA3B 44BD A7E3 36FD7C80A033 7543ED84 460F 4AE9 A1EE EEBDBBE75304 AF7DDEFD 7187 4BCC B5BA BCDFD5F9B647 1C576AC6 D25C 4DD2 9252 7AE21A75F60C 6FE90CB5 9E18 441E AD1B B70F9CD69600 F63D9B58 1CE6 4A7C B212 4D51F5DAF90D 09AE1704 E8EA 4007 AD68 3A2FD448CA3A 897CCDC4 E93E 41A7 BF80 299A2B92193D
kandt
kandt
126
762
Bluegrass state
Well got the final version of the glove box plate. Ian at Crossroads 3D has been great to work with to get the plates right. I believe he is as OCD as I am. This one mounted to the matching holes on the lid. Used rivets to attach. Ian sent some push pins that would have been great but decided to got more permanent route. Big thanks to Ian.
D460A649 2C01 4BE0 903A 33DD16318CA8
kandt
kandt
126
762
Bluegrass state
You may want check this mod out. It would be perfect for duck hunting.
If that doesn't work for you, you could they this mod. Just trying to help out.
Haha. Looking to add a set of these to take care of any problems. But our pit field averages about 8-10” of water. Should be in good shape. Appreciate the suggestions.
Nice to know folks are watching out for me😜😂😜
2D3FD57D 410A 45F9 96D7 C6ADA8CA3BE5
kandt
kandt
126
762
Bluegrass state
Big shout out to @Hondasxs for the DIY fan override kit for 2022 PK5. Sent a kit to run with my auxbeam control box. Plugged in and wired to box, worked like it should.
NOTE: when taking the factory plug a part press on the top center and it will release tabs and pull up and out.
FC8D59F8 B68A 4B4F A93A 5B7A434828ED 8AC6B692 0783 4265 8002 0A602304C1E6 D3874584 E6D8 463F 8CFA 9D3DE4CAE3BD F9A36A69 E4E3 4418 9265 5A1D2B1AB868
kandt
kandt
126
762
Bluegrass state
Finally got some decals in and on. Wife even liked them :D Still have a few things on the list over the next year or so to add but About where I want to be. (I know just wait💲💲💲:p).
great site with great info and people. Appreciate all along the way.
A533D037 5CE3 446B B1FD 7C629022D4CD 4228F9F8 F2B0 4131 BF7F 29BE82CD3244
GRANITE
GRANITE
1,100
5,550
Brookville, Indiana
Did you ever get that mount figured out for radiator fan under seat? Also how is that sound bar?
Reactions: Biteme
