97 Power stroke F350 build.
What Color to paint the Truck?
  • Factory Hunter Green
    Votes: 11 37.9%
  • White
    Votes: 12 41.4%
  • Other
    Votes: 6 20.7%
  • Total voters
    29
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
Stacks anybody?
9536FA44 D385 4899 8749 8BAA9C4DD783 56601D66 F7CE 430C 8B08 93D414E83BFF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Got a few more lights wired up. So much soldering and soldering and more soldering lol. Only one more side to go.
Looks awesome man I love the lights. Especially the reverse lights.
Don't forget to have a good system for your ramps to hook into.
Lookin good
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yessir. I’ll have a couple of straps and d rings on the ramps to keep them from sliding.
A friend made a set that hooked into solid slots on the back so he didn't need straps. then the side of the ramps had square tubing welded on and they set Into the stake pockets on the side of the bed.
They were 8' long and it was nice they doubled as bed sides.
Kilo427
Kilo427
1,543
6,439
Exactly what I plan on doing
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
That’s more or less what mine are now, they have a lip that hooks on the edge kind of. Eventually it will have a winch so i don’t even have to drive it up. I’m setting mine up as a stake side of sorts as well but they are only 6’ long.
66,351
Gonna have this bad boy ready by the takeover?
popeye
popeye
3,273
14,641
kapowsin, Wa
Your flat bed is 9’ right? Is that the bear minimum in length that it would still fit? If 9’ long what did you do after the frame rails to help support the weight of the rear end of the machine. Do you still have a useable hitch to pull a trailer?
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
Mine is 9’5” long. I used 4x4 cross braces along with 2x12 side rails and 2x10 deck boards. The tires sit directly on the cross rails. I used a 6” extension to still have the hitch sit flush with the back bumper.
9856B9AF 8ED7 431D 8586 F47B08845566
popeye
popeye
3,273
14,641
kapowsin, Wa
So the extension is like a super hitch? Do you think that the extension will need any extra side load support? I think the super hitch’s run chains out to the side of the frame. Was 9’6” the shortest you could go and still get the 1000 to fit? I’ve been kicking around the idea of doing a flatbed too
