moparornocar
RIP....Rocmar...
I needed them to position everything. I got a Tig welder buddy that’s gonna stitch them all together for me once they are where I want them and all together.Clamps???
I will send you pics of my scrap bin at work tomorrow.....
Looks awesome man I love the lights. Especially the reverse lights.Got a few more lights wired up. So much soldering and soldering and more soldering lol. Only one more side to go.
Yessir. I’ll have a couple of straps and d rings on the ramps to keep them from sliding.Looks awesome man I love the lights. Especially the reverse lights.
Don't forget to have a good system for your ramps to hook into.
Lookin good
Did you get the air bags installed?Got a few more lights wired up. So much soldering and soldering and more soldering lol. Only one more side to go.
I’m doing another row of lights under the doors and under the front bumper. I added it up and it should be somewhere around 90 lights all said and doneYessir. I’ll have a couple of straps and d rings on the ramps to keep them from sliding.
Nope, not yet.Did you get the air bags installed?
So, airbags, stacks,more lights, what else?Nope, not yet.
A friend made a set that hooked into solid slots on the back so he didn't need straps. then the side of the ramps had square tubing welded on and they set Into the stake pockets on the side of the bed.Yessir. I’ll have a couple of straps and d rings on the ramps to keep them from sliding.
They were 8' long and it was nice they doubled as bed sides.
Bags, stacks, lights, paint, tires, brakes, front bumper.So, airbags, stacks,more lights, what else?
That’s more or less what mine are now, they have a lip that hooks on the edge kind of. Eventually it will have a winch so i don’t even have to drive it up. I’m setting mine up as a stake side of sorts as well but they are only 6’ long.A friend made a set that hooked into solid slots on the back so he didn't need straps. then the side of the ramps had square tubing welded on and they set Into the stake pockets on the side of the bed.
Gonna have this bad boy ready by the takeover?That’s more or less what mine are now, they have a lip that hooks on the edge kind of. Eventually it will have a winch so i don’t even have to drive it up. I’m setting mine up as a stake side of sorts as well but they are only 6’ long.
Maybe, but still going to bring the Durango most likely. Don’t know if I’ll have the budget for 6 new tires and brakes on all 4 corners in a months time.Gonna have this bad boy ready by the takeover?
Mine is 9’5” long. I used 4x4 cross braces along with 2x12 side rails and 2x10 deck boards. The tires sit directly on the cross rails. I used a 6” extension to still have the hitch sit flush with the back bumper.Your flat bed is 9’ right? Is that the bear minimum in length that it would still fit? If 9’ long what did you do after the frame rails to help support the weight of the rear end of the machine. Do you still have a useable hitch to pull a trailer?
