Adam490's 1000R Live Valve Build and Shenanigans
Hometeam
Hometeam
943
3,733
Normal, IL
Added about 500hp today 😁 .... @snuffnwhisky
What did you all change from the factory tune? I have been looking for a little adder if possible. And since we have the same machine, which I felt mine was faster than yours last time we were out!! Which is probably why you got tuned! Just sayin!! 🤣 😎 🤥🤣
57,123
Yours was definitely faster on our last ride. Can't go fast when I can't see, window open, and it's freezing balls out, hahaha! Hopefully that problem is resolved...
@snuffnwhisky worked a little magic. There are a few of us running it now on the Talon. Here's what he updated versus the stock Talon tune:
1650208827096
It's A LOT better on the bottom end when you are slow crawling. Got rid of most of the torque management so it doesn't bog down when you try to bump up against something and go. I haven't had a chance to really rip on it since I had the kiddo on it's maiden voyage, but it was noticeably better in the slow rock sections.
208,029
@CumminsPusher this is what I was going to call you about. Snuff is brilliant, I copied his valving for my Elka's, works great even on a P1.
57,123
Once we get some more time on it I'm sure @snuffnwhisky won't mind sharing. Right now it's only a few of us and all 3 of us have different Talons. 4xLV, 2RLV, 2X. @Remington buggy was the test and tune rig and it's pretty awesome.
107,788
Yup! The thing is a Ripper!
had it out this evening and Id take that thing up against any aftermarket tune any day of the week ;) 🥳
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,155
Cullman, AL
  2. Other Brand
I did a lot of Dragy runs and datalogging on Remi's machine. 15% faster to 10mph and 5% faster to 60 mph, all stock with 31" carnivores (KRX Takeoffs). I do need to get the other Stock files. If anyone has a PV3 and can email me your stock file, it would be great. I currently have 1614003, 1614004, 1614005 & 1614006. don a@t nexaninc d.o.t com
107,788
That aint no joke!
when @joeymt33 and I took off in low with mine from a stop, the G’s were insane and sucked u into the seat for 3 whole seconds easly.
todays run I got to 55mph before a turn so I had to back off lol. But n the sugar sand it was still quite faster than what I remember in a stock set up machine. shifting is also improved and smother from gear to gear and going into gear.
Snuff, you once called it a RIPPER
when u gave it back to me. That is every bit true and i use that to describe it when Im asked.
Hometeam
Hometeam
943
3,733
Normal, IL
Will I need a PV3 to do any of the tuning from you or is it just a flash? If so I can pick some up and send you 2 files off mine....
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,155
Cullman, AL
  2. Other Brand
U will need a PV3 to flash the machine. It can be yours or someone elses but a few more steps if someone elses. Got to buy a license from DJ if using someones PV3, $225.
7,169
27,418
Does anyone have a contact to purchase the PV3's? Maybe we can get a forum sponsorship out of someone if we all buy from the same place.
Or @Hondasxs could buy one and we could all use it and just buy a license!
