Beadlock Maintenance
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Never had beadlocks before, but decided to try them out. How often are yall checking the locking ring bolts? Also, did a shop install the wheels for you or did you do it?
Ive debated about getting a shop to remove my old tires and then ill install the tires on the beadlocks.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Beadlocks are time consuming to mount correctly...but its is pretty simple. All you need is some soapy water..wd-40 , and a torque wrench. As far as checking them when i mounted mine i never retorqued them until i changed tires. Probably should check them every 6 months or so. Or if they start leaking.
I was very very thorough when I torqued them down to make sure it was even and equal within torque specs.
I installed them myself, make sure you give yourself some time to torque the beads down it’s not a quick process if it’s done right.
Yankee
Yankee
280
723
Tennessee
I bought a set of double beadlocks and love them. On that same note when I go to put a new set of tires on I'll take them to the co-op. Torque wrench is not usually in my vocabulary but tight is. If u don't want them to leak torque wrench is the key. These guys r right
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Sounds like ill get the tire shop to remove my old rims and then install the beadlocks myself. Ive been wanting new wheels. Decided on beadlocks and come to find out later that they actually involve me doing work haha. Normally i do my research before i get something, failed this time.
Reactions: ohanacreek
