P1000 Bilge Fan questions...
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Got my 7" fan in yesterday. Gotta figure out how I want to mount it and will see how it works.
Reactions: CumminsPusher
WHITEP1K5
WHITEP1K5
48
72
WEST VIRGINIA
Thought I posted these in this thread, but it was a different one lmao. I installed my 7" without drilling holes just made a couple brackets.
IMG 0280 IMG 0281 IMG 0282
322,675
322,675
Mine was better pulling. I think it has to do with the way the air comes in because of the shroud. Down the road I'll get another cheapie to bolt just it's shroud on as well
WHITEP1K5
WHITEP1K5
48
72
WEST VIRGINIA
Did you find yours does a better job set up for push than pull?
Mine seemed to pull better than push, I took the fan blade off and flipped it over to make it push better than pull I also wanted the fan motor and guard side against the seat where there would be less of a chance of the fan motor to get wet
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
How did yours turn out? I'm looking to add this to mine this week. Also how did you route your wires?
ran them along the factor air intake. works pretty well. haven't had a long trail ride to try it out. but just riding around with the kids i can turn it on and the heat goes away
CMH
CMH
25
42
Montana
Got mine installed over the weekend. I went with the 7" fan, a variable speed control and a master switch. No pics, but it works sweet! If you turn it down to about half power it is significantly less noisy.
CMH
CMH
25
42
Montana
Ran mine in a 3/8" plastic wire loom right next to the big factory bundle - under the floor and up into the dash. Also routed wires to a backup light along roof and down ROPS post to tie into loom, and then ran all four wires up to hood/in front of dash area.
nerd
nerd
53
128
KY
Are most people putting vents in? I put a 7" fan in but no vents and I think it's just recirculating hot air. I feel like vents are the (fairly) obvious solution I overlooked originally...
K
Kolton
117
82
Vance, al
I used 2 4" fans, no vents. I just pointed them towards the back and angled the one under the driver at about a 45 toward the passenger side. It made a huge difference. The only time I feel heat is when going fast the air can still draw out a tiny bit around the seat belts. Where is yours mounted?
nerd
nerd
53
128
KY
Under the seat closer to passenger side blowing straight back. Ordered a 4" vent tonight, will try that next week. I think it should help for hotter days
IMG 4644
Reactions: Kolton
misterkit
42
36
ny
Anyone have these setup so that the fan can reverse direction on a switch? I'm thinking a rocker switch for heat at one position or cool at the other. That way during cold weather you get the heat or during warm weather you can push it away.
Reactions: Kolton
K
Kolton
117
82
Vance, al
I would think that would do it. I'm sure you have but gong to say it anyway
... have you checked rotation on the fan?
nerd
nerd
53
128
KY
Yes, that was my first thought too.
Curiousity got the better of me so I drilled 4 1" holes (largest hole bit I had) in a cluster for a vent. Rode for a while today and it definitely made a difference. I have a 4" vent on order so I'll see what that does - may have to expand it to 6" but we'll see
Reactions: Kolton
K
Kolton
117
82
Vance, al
I'm back and forth on cutting vent holes. Amazon has some nice looking vent covers to make it look good
