P500 Bucket seats question
Shadesmn
Shadesmn
505
959
Ramsey, MN
Just wondering how many people have done a bucket seat conversion and if its worth the time and effort. I can get some rzr seats for 25 bucks each, wondering if theres enough benefit to doing it or not. Or if rzr seats are a waste of time..
HUCK
HUCK
1,047
2,315
ARIZONA
RZR seats are 100 times more comfortable in a RZR but they may suck in a Pioneer . Dont think they will have enough room to lean back like they do in the RZR
34,175
I'll take those seats if you don't want them.
Shadesmn
Shadesmn
505
959
Ramsey, MN
The rzr seats? How many would you like? They are on Craigslist about 40 min from me. Not sure how many he has. There are three i his pic, could be just 3, or maybe more..said hes cleaning out his garage. EDIT, i assume youd like a pair. If hes got more i can certainly grab them for you
Shadesmn
Shadesmn
505
959
Ramsey, MN
@Montecresto, I'll text him in the morning and see what hes got
Reactions: CURTK
34,175
Yes, 2 of them.
Shadesmn
Shadesmn
505
959
Ramsey, MN
@Montecresto, He already sold a pair, only has a single left...:(. guess I have time to do more research while I watch for more to become available
34,175
Oh no, I don't expect you to do anything, I just thought if there was something right there available I'd jump in on it.
Shadesmn
Shadesmn
505
959
Ramsey, MN
Well I'll keep you posted if i see any more pop up for cheap like that. I'm going to do some measuring off my buddies rzr and see how easy or hard a conversion would be.
34,175
Jackal put buckets in his P-5, though I'm not certain they were from a RZR.
Shadesmn
Shadesmn
505
959
Ramsey, MN
No, his were beard suspension seats. I did read that build a while back though, its what has kept the idea alive in the back of my mind though.
34,175
Yep, you're right, that's what they were.
267,635
My conversion starts here and following posts showing how I mounted it.
P500 - Jackal's P500
Reactions: Shadesmn
267,635
I read yours again this morning. Love the way they turned out. Hoping I can do the same, but with less costly seats. :)
Gotcha, word of caution will set you about 2" higher and about 2" farther forward. Only real pain is if you have an overhead soundbar mounted in same location as mine and are 6ft or taller will bump your head getting in and out occasionally, once seated it is not an issue unless not wearing restraints.
Reactions: Shadesmn
RODNUT
RODNUT
26
I put a pair of Standard suspension seat co. buckets in my p500 without too much fabrication, like was said earlier 100 times more comfortable than the stock benches. added a set of Beard 4 point harnesses and made things much more secure and comfortable, especially on rough country.
162,141
Pics please.
I looked at that build probably a dozen times and that's why I didn't do it. Pushes you forward and up and there just isn't that much room to be had in the 500. Seat back looks pretty vertical too. They look nice but...
267,635
Pics please.
Ya to do it right would need to drop the supporting frame rails 3 to 4 inches but then knees would hit steering wheel. I did the best with easiest reversible route possible. FWIW I use the OEM seats for everything, the others are a PITA for getting in and out. Comfy while there, just not the complete package.
RODNUT
RODNUT
26
Did a writeup on this install some time back, on this forum, I'm over six feet and am very comfortable with this set up.
IMG 0124 IMG 0618
Reactions: Rustell and trigger
