P500 Buckets in a P5
178,901
Well I bit the bullet and ordered some bucket seats. Rzr 1000's to be exact. Researched the hell out of everything available until it was giving me headaches. I've looked at every size, style and price. From $100 go cart seats to $1500 Simpsons. PRP, Beard, Corbeau, Kirkey, NRG, 50 Caliber, Braum...I know more about bucket seats now that I ever thought I would. Settled on these for a few reasons. One is that they're two piece fastened together with a bracket. This will help with the install and also facilitates water and mud draining off the seat into the space between them. High end seats that are one piece have a vent type thing built into them for this, the cheap ones don't. Size was another, most are just too damn big for a P5 and even these aren't small. Have read through the forum on anyone who's done this mod and it always ends with they move you forward and up. Jay Man made a video of it and at the end of the thread said he was going to do something about that issue, haven't heard from him since. Well I intend to do whatever is needed to avoid that issue, I want to move back and down so it probably won't be a quick install. Might take some cutting of things that I don't really want to cut but probably will never go back to the bench seat anyway. Will probably have to modify the Trigger Shield and build a new console. Considered Chooglin's console but that's made to ride above the bench, not in between buckets, I should end up with a longer and deeper console but we'll see what I'm left with after they're put in. They also make seat covers for these that are BA, options for different colors of materials, panels and thread. They're not cheap but even all in will be cheaper than a lot of aftermarket seats.
Anyway, figured I'd start the thread with this and then take you guys along for the journey. I don't mind spending a few bucks if it means turning out the way I want it to and might save someone else the trouble of trial and error if they decide to follow. Kind of looking forward to this one as I don't have to disassemble half the machine to do it.
Btw, this is it and then I'm done. :D
Rzr Seats
272,158
@trigger I wish you luck on the conversion. You know I did it 4 years ago (Didn't seem like that long ago but was May 2015). Probably works ok for someone under 5'8" and under 180 lbs. But my big ole ass felt like I was driving a forklift and ended up taking them out. They were comfortable once you were in them but if you needed to get in and out several times a day it became a PITA for a person my size. But they looked cool :cool:
20150912 132204
20150912 132124
115,761
You say there not cheep! So.....how much?
Reactions: trigger and Mudwing
178,901
Yeah, I remember reading through that thread several times and actually revisited it just the other day. The look of those Beards in your machine has stuck with me since the first time I saw it, BA! I was looking forward to seeing it in person at last years Takeover too but didn't know you had taken them out. Well I'm not under 5'8" or 180 lbs so that's a little disconcerting. Being two piece I'm hoping it gives me a little more options on placement. Thanks for the wish of luck, I think I'm going to need it.
snakeriver
272
596
Clarkston Wa
Have we not heard this remark before??? Sure you are....
178,901
The only other ideas I've had are a glass windshield and build full doors. They're just ideas though and I have no intention to act on them, maybe someday. Anything else would be drastically altering the machine and I might as well buy something else at that point.
178,901
Seats showed up today. The ad said they were used but had a note that said even if seats are installed in a machine and then taken right back out they are considered used. I was hoping for a set that weren't all rusty and stitches unraveling. Sure enough, these things are brand new! I mean they've probably sat in a warehouse for a bit but they haven't been ridden at all.
Just sat them in there to get a look at things, there's room for a console and I've got some ideas already. Had the brackets under them so they were sitting pretty high. Bought two pcs of 1/4" aluminum 2'x2', DAMN that sh**'s expensive!
Seats Seats 1
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Those seats look very plush! I bet they were comfortable! Nice work @JACKAL :cool:
snakeriver
272
596
Clarkston Wa
View attachment 138076 View attachment 138077
Looks good ...keep us posted with a lot of pictures on your installation....
178,901
Put the driver's side in today and the front of the seat ends up being about 1 1/4" higher than stock but the back is only up a little. You do feel like your sitting a little higher but going any lower wasn't an option with this seat. I was able to push it back though by notching into the plastics, keeping set angles on the new seat I was able to push it all the way back to where the factory headrest used to be. I'm able to get in and out without noticing much difference really. It is a more comfortable seat though, lumbar support, better angle, and the bolstered sides hug you in. Feels cushier.
lee
lee
Village Idiot
2,387
13,521
Springfield Ohio
Hey @trigger, the Popo seats have a fairly flexible frame.
The frame adds to the comfort of the seat as the seat back is not stiff when your body slams in to it.
Something to consider when mounting, allow some space for the back to move or add a cushion for it to stop against.
You might consider bolting a seat down to something solid and testing how much movment you need.
Food for thought.
Personally I was considering what parts of the seat frame / ROPS might need to be re-located to allow the seat to fit where I want it.
The cross bracing behind the bench seat back needs to tip out of the way to the rear - sacrificing cargo space.
I like the idea of the Talon seats but I can see the supply of RZR seats is pretty good. (Seat cover is a great idea to remove the embroiderd name)
But I need to pick a seat first before I get serious about cutting metal.
Reactions: trigger
