Hey @trigger, the Popo seats have a fairly flexible frame.
The frame adds to the comfort of the seat as the seat back is not stiff when your body slams in to it.
Something to consider when mounting, allow some space for the back to move or add a cushion for it to stop against.
You might consider bolting a seat down to something solid and testing how much movment you need.
Food for thought.
Personally I was considering what parts of the seat frame / ROPS might need to be re-located to allow the seat to fit where I want it.
The cross bracing behind the bench seat back needs to tip out of the way to the rear - sacrificing cargo space.
I like the idea of the Talon seats but I can see the supply of RZR seats is pretty good. (Seat cover is a great idea to remove the embroiderd name)
But I need to pick a seat first before I get serious about cutting metal.
Lol, you're right, picking the seat is the hardest part!
I didn't find moving it back any further as an issue. Again I'm trying to keep all factory set seat angles the same and I was able to get the front of the seat bottom flush to the plastics, maybe even back a little. The seat back ended up about a 1/2" from hitting the empty head rest area, but I drew that out of it when fastening it back. Figured it would rattle and drive me nuts. Could put a rubber spacer there and I think I will, good idea @lee !
Moving it down would be the only thing worth cutting anymore than I have and that would be involved, especially keeping the seats easily removable. It can be done but would also remove a layer of protection that I'm not willing to sacrifice. I have my second battery under the driver's seat and the gas tank's on the other side, for the little it's moved me up I just can't justify it.
