P1000 Cage chop
105,499
Is it a P1K5? You got any pics of this chop? Maybe a side view?? I was thinking doing 4 all around but may like the 5 at the rear
I did 4-1/2 all the way around. I can change some preload if i want to drop or raise it. But i think its fine the way it is.
6CA420AA F38B 4E63 889F 51A5E366654C
082EE9EA 7C31 4094 87B3 74F94AA63301
JenElio
JenElio
64,402
603,903
Loxahatchee, florida
105,499
Nice!!!!
I'm thinking about doing 4" around. I don't have a issue with the garage doors. I really just want to eliminate the "boxy" look 😃
Thats what i wanted to do is get rid of the boxy look. Also i did the 4-1/2 to mimic @joeymt33 set up cuz we both have CEC enclosures and he has a templet to cut it down to fit or joey will send him his if he lost it lol. But i like the 4-1/2. Im 6-3 and it just right for me.
105,499
Yeah I definitely want to sleeve as much as possible. Did you use the 1.625 OD pipe for all pillars?
No, i used that for the A&B pillars and 1-5/8 for the rear. Had to leath them down a couple 1,000 to get them to fit. Very hard to find anything that fit that tight to sleve
Reactions: JenElio
105,499
also, after i sleeved, i drilled 2 holes in the cage on each pillar and did some plug welds to the sleeved pipe to make it even stringer
Reactions: JenElio
JenElio
JenElio
64,402
603,903
👍 thanks!!
Reactions: Remington
CGD
CGD
SE Missouri
Did you cut your windshield yet Remington ? I want to chop mine soon but I want to make sure that I can keep my SATV windshield.
Reactions: JenElio
JenElio
JenElio
64,402
603,903
😂😂 that's actually my biggest hesitation too. I know it's not that complicated but still a $400+ pc of plexy 😂
Reactions: CGD
JenElio
JenElio
64,402
603,903
105,499
Hey Rem did you have to extend the top/vertical ROP? I've read some people say yes and others say no??? roof lines back up good?
Yes you do about 1-1/2” to make the difference with my 4-1/2” cop to most importantly get the proper angle of the windshield or it will almost be flat or flatter up and down. As you shorten your cage, the geometry changes so u have to extend the top by adding a sleve. That pipe i leathed, i cut 2 pices at 3” long from the pipe to use as a sleve for the extension. Worked perfectly .
91A338E2 B9AE 40DE 8DCE FD8F3D0B73DC
JGarner
JGarner
14
17
Silver City NM
I did a cage on my 2020 Deluxe I used Hogans Measurements it’s came out really good! I sleeved mine with 11/2 tube left about a 1/8 inch Gap to weld to and buffed it off, the hard part was fitting the SuperAtv Window back in had to cut about 4” off the Top half.
F64E8471 D69C 4C90 AF10 64F139D318A9 BD0EB5FD 1C3D 4B4F A25D 36FACCCBBC3C 6B322D6E 5B30 4C73 9FAD 4BE1854D89D8 D86F0BB6 EB88 48DE 8C6B 8AAC1267B91D EC417D91 8C2E 465A 8812 06B0FA8FB3F1 80BE633D 0C48 4935 B16D 64BFE4D863A7 18E23739 9B90 4027 BE30 08C14BB739A3 A5DE8433 12F2 40E2 AE07 E9D14FE0D2A4 47BF3A49 5427 4FBD A6E4 8C6F35D2C4F2 A9516CC0 5E9F 43E8 8A2E 92BF02F8E588 50A78058 7E67 4387 BA39 E10EEDDC48CB
105,499
View attachment 271680 View attachment 271681 View attachment 271682 View attachment 271683 View attachment 271684 View attachment 271685 View attachment 271686 View attachment 271687 View attachment 271688 View attachment 271689 View attachment 271690
Looks great man!
How did u get the right measurements for the brackets on the windshield if you dont mind me asking?
JGarner
JGarner
14
17
Silver City NM
Looks great man!
Latched it on the bottom laid it on the brackets and drilled new holes, it took some trial and error to get it right, had to cut some new notches in it to get it to open to the full open position goes closer to the roof now then it did, took a time to get it right!
105,499
Thanks. I need to do that to mine. Im scared ill Fuc it up! Lol. I know your quite busy when your doing that, too bad u didnt have any pics of the process. Either way, you did a nice job.
P1K5Dave
P1K5Dave
2,172
8,120
Petoskey, MI
Man, I wish I could chop my top. But I've got the Audioformz stereo roof and I wouldn't have the headroom to do it.
They look so much better, but I love my rockin' tunes too much to give it up.
