P1000 CB Radio ??
Cattrell
Cattrell
49
81
Church Hill TN
I am looking for a good way to communicate with other riders on the trial. I was thinking of a weatherproof CB or something similar.
Has anyone done something similar?
Looking for ideas!
Thanks
66,869
Hi.
You should check with your riding group to see what system they use.
Most riders seem to use UHF radios vs CB radios.
mike621
Roseville
Most everyone uses Rugged Radio, they have a wide range of hand held to full on intercom systems. They have a good wed-site.
Cattrell
Cattrell
49
81
Church Hill TN
Hi.
So far nobody has anything, so we are open to suggestions. Can you suggest a type of radio?
66,869
RR or similar is what most of use use.
66,869
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
Like this - https://www.amazon.com/dp/B07F3WXL2V/?tag=sxsweb24-20
Or handheld like this - https://www.amazon.com/dp/B00MAULSOK/?tag=sxsweb24-20
You will need to read up on programing them along with use restrictions.
Or go with RR which comes programmed. (I think)
the Radios that Richard links are great little radios that work good for the trails. (note that to be all legal you need to get a GMRS license $70 for 10 years or something like that - providing that you use on GMRS freq)
you can usually purchase basically the same radios Rugged Radios sell but at a much cheaper rate - they program in the frequencies but the same rules apply if using GRMS freqs (they just don't tell ya). They also program some other freq like ones used at King of Hammers in there.
Lots of information on here in several different threads
60,375
Betner communications is also a good option if you want a pre programmed option ready to go.
Looking at these for the Black Friday sale. Any input on this model he's got?
Upload 2019 11 26 9 25 3
Reactions: BWAF and Ragnar406
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
It is probably a good radio- it does come with an antenna , coax and ground plane disk ( you may end up purchasing another mount depending on how you want to mount your antenna.
Pro's
  • Kenwood - good brand makes quality equipment
  • comes with antenna
  • comes pre programed for GMRS channels (pretty much what everyone uses) Edit to add write up states only 16 channels (total)
  • 40 watts
Cons
  • Not sure if you can program or if it requires additional programming cables and program
  • how water resistant is it?
  • UHF only (GMRS is only uhf frequencies so fine there and really not a deal killer)
Upload 2019 11 26 11 2 19
the radio will serve you fine and I hear the guy is good to work with and will answer your questions happily
That said an option (that I went with and several other have) is TYT TH8600WP - only 25 watts but waterproof or at least claims to be and I have power washed mine too many time to count. User programable and there are files passed around this site that make that easier.
25watts is plenty for use on the trail - UHF is line of sight so if you are in the bottom of a holler don't expect to talk to a buddy in the holler on the other side of the ridge no matter the wattage.
You will need to buy an antenna, mount and coax to go to the radio if you choose the TYT TH8600WP
Hope that helps
60,375
Pro's
  • 40 watts
Cons
Hope that helps
Exactly what I needed - thanks! I have been reading through all of the other posts trying to piece it together but you just consolidated for me. I'll stick with the TYT TH8600WP.
Reactions: BWAF and JTW
Pro's
  • 40 watts
Cons
Hope that helps
This....
I won’t say ours is a better radio. But we know the system.
Reactions: BWAF and Adam490
L
LewisStephens
Texas/Arkansas
Pro's
  • 40 watts
Cons
Hope that helps
Isn’t this an amateur radio requiring a license?
Reactions: BWAF
66,869
Technically yes. Just like you cant throw away AA batteries, vanilla flavoring or drive a car without your seatbelt on.
Get a GMRS by just paying the fee and it covers your entire "family" for 10 years.
Russ989
Russ989
22,642
147,257
I feel enlightened now, so much knowledge in one spot.
