P1000 Chop Top Club
JenElio
JenElio
73,303
666,986
Loxahatchee, florida
Hey all...new guy here, but what's the right amount of chop on a 1000-5 to still be able to sit people in the rear? Chop look is legit but if I can't sit anyone in the back because they smash their dome, it becomes a form vs function debate.
Lots of factors there.......sit back there and give your self what ever "head room" you want to have. I have a 5" chop at the rear and also have RZR seats installed which bump you up a few inches also. Plenty of clearance, but I also have the OEM roof which gives me another cpl inches over the cage.
Shelly
184
514
Shelly
184
514
CumminsPusher in one of your chop posts I believe you said you have to add to the middle bar. How much do you have to add? If I did a 6” drop in front and 5 in the back would I have a piece or pieces long enough to add what is needed to the center? I have a couple of friends who are going to help me with this and they are asking. I will mostly be the gopher on the project.
Reactions: Lady01
322,690
I better it was 1.5 added to upper center sides. I’d suspect you’d be somewhere around 2.25. And yes you will
Reactions: Lady01 and Shelly
Shelly
184
514
Thank you. I have another question. Do I need to order any type of weld in bungs?
Reactions: Lady01
Shelly
184
514
And yet another question…sorry. Is there tubing that fits the ID of the roll cage or will it have to be turned down?
Reactions: Lady01
322,690
Man it’s been so long I don’t remember ID. Just did friends few months back and we had enough laying around. I think someone said the smaller diam tube will fit in larger but I can’t confirm. I did do a thread that had some of that in there
Shelly
184
514
So if I am facing the front of the rig is A pillar the one on the drivers side then B is passenger side?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Take the stock tubing you remove, cut out a small strip lengthwise and squeeze with vise until they can be pushed down into your cage
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
On this one I used 1.75" .095 tubing but I don't really recommend it. Had to take a sizeable strip out and pretty hard to compress. But it's strong AF.
On this one I think I took 3.5,4, and 4.5 out of it starting with A pillars.
20220320 133039
322,690
I personally like taking more out the front, makes room good in rear and evacuates that damn pool that sits on factory roof out
Reactions: Shelly and Lady01
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,525
Oshkosh, Wi
This is what I used.
This fits snug in the a-pillar and c-pillar. It will require a slit for the b-pillar. I replaced the bung on the a-pillar and added a sleeve up the a-pillar with the tubing. The b-pillar, I did a z notch to keep all the stock gussets and I added a sleeve. The c-pillar I sleeved with 30" of tube from the top to the bottom bend radius. Weight or cost wasn't a concern but it's stout. I did not added any tube between the a and b pillar as I only went about 3" lower than stock.
