P1000 Clutch update reviews???
Kenjones21
Kenjones21
165
107
Central Louisiana
Anyone have any real time testing on the new clutch update, I seen some say it shifts better in high but no one ever said anything about low range, I'm wondering if it helps with the shuddering on inclines at low speeds also if after updated if the machine can go any slower than before as far as crawling, slowest mine will go is 3mph?? Thanks
208,726
It is supposed to take shuttering out, we'll see?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I’ve got about 100 miles on mine after the update and honestly I really can’t tell the difference! I’m thinking this update will extend clutch life not prevent clutch failure or drastically improve performance!
Low feels about the same when climbing at roughly 3 mph and as far as the shudder I experienced a slight shudder while in 4wd High in auto mode! I will review some of my video from the last ride to see if I have anything to support my experience!
At the end of the day I am hoping for extended clutch life.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Correction*
I have over 217 miles on since the update:rolleyes::D
81A768F6 6341 4695 A82E 9BF45D65BF0D
DACE261F 8E43 4F66 A17A AA94368665EB
Reactions: CumminsPusher
Hawk53
Hawk53
481
614
Alberta Canada
Having a hard time understanding some of the reports that shift solenoids are quieter after clutch up date. Thought the update supplied more lube to the 1-3-5 clutch. Any ideas?
Reactions: lee
lee
lee
Village Idiot
2,387
13,520
Springfield Ohio
I spent 2.5 hours driving a P1k-5 around in circles, slow, 2 footing crawling over rocks and freeking rail road ties this afternoon.
Used the clutch like a torque converter - its a wet clutch so it should be able to do that all day long if its designed right.
Watch this vidio, explains it better than I ever could:
P1000 - Weak clutches?
I don't think there is any difference in how it 'feels' with the clutch update.
But it seams to work like I think it should (so far).
As for the cabin heat "fix" I froze my ass off, it was 35 degrees out and no windshield.
Hondas' smokin the good stuff to release that going in to winter.
It's probably a plot to make me break down and get a windshield
Hawk53
Hawk53
481
614
Alberta Canada
Windshield is great when temp drops unless you want to wear snowmobile suit and helmet with shield
Watch this vidio, explains it better than ever could:
Lmao!!!
Having met you it’s waaaay funnier now!
MountainMan
MountainMan
54
Spokane Valley, Washington
I have ridden about 50 miles since the clutch upgrade. I had my first service at the same time. I used 10W40 oil instead of 10W30. I can still hear the clutches shifting. However, the jerky nature at low speeds gas been substantially reduced.
Sent from my SM-G930V using Tapatalk
HondaTech
What I've found in the several I've done is that a fresh clutch or new unit combined with this update makes the machine feel completely different. Almost gives it a slipping feeling on take off and the shutter climbing hills is gone.
It seems the machines I don't install a clutch on (because it's acceptable within limit) the feeling is a little better than without. Shuttering is a little noticeable but not as bad, and take off isn't quite as smooth as a fresh clutch.
That's my take, every units seems different. I've ridden some that are amazingly smooth without the clutch update and some that are crap. I guess it's just depends on tolerances in the engine.
322,690
That's my take, every units seems different. I've ridden some that are amazingly smooth without the clutch update and some that are crap. I guess it's just depends on tolerances in the engine.[/QUOTE]
This is exactly what I've found and have mentioned. Each rig veries, most are very good, some exceptional and some not so much.
Some people just don't get this. Whether it's the guy with the perfect machine that says it'll take anything to the guy with issues saying it's junk. Been there in both situations lol. I've driven as many p1k's as anyone but most I've been lucky enough to give a little hell. Fluid "drive" is awesome but not without issues. You have a great one you are god, most are very very good but however some...
I've driven few other machines that touch a Pioneer and it's because of that transmission. Nothing like being in the right gear at the right times regardless of auto sport or manual! Nothing like going through the gears in a technical trail. Even a very good belt just doesn't touch it.
Keep hearing questions about comparison on the x4. It's hard not to comment because we were lucky enough not only drive one but to run it in our very tight technical spot in the woods. Well... guys it's good. Very good. Lots of miles in a Pioneer here, so my impression (not needing the high top speed because we live for low speed technical not dirt roads) it's good. But just not near as good in some ways as Pioneer. Pioneer is fun! Wolverine x4 just goes. Bottom line for all that ask, the Pioneer p1k5 is the most fun at getting the most throw the woods. It's a beast and fun as well as dependable.
For how we ride there are two multi passenger Sxs's that'll go. X4 and p1k5. Both good, one better, PIONEER! I'll b**** sometimes but I'm still in. The Pioneer just rocks. Always overly honest here regardless (I do want to get four x4 buckets for PJ after the experience lol) but had we wound up with the x4 it wasn't a replacement to the Pioneer but actually to the 700 Wolverine which omg in many levels no. Greatest team imo for our family is PJ and our 700. Not changing and I'll be leading our team with PJ :)
Tramguage1
Tramguage1
Texan
7,478
30,587
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I was fortunate enough to participate in the 2017 Overland Adventure, I rode in at least 3 different P1k's. Every one shifted different and felt different! Not sure why this is but I also saw 3 completely different driving styles, all three of these felt different than mine! I would have expected a little more consistency. Not sure whty this is the case unless its the way the owner breaks them in differently.
I think the transmission learns your driving style??
I’d look but my owners manual is in the glove box, and it’s buttoned up to go riding shortly.
Reactions: lee and Hawk53
208,726
The oil relief valves have been chamfered along with the different clutch cover for more oil flow to the clutches
Reactions: Hawk53
So what are you saying @ohanacreek?
You and my P1k think I drive like a jerk?
No judgement here I’ve seen you put that 500 in places guys were to timid to take a 1000.
You’d have to talk to a Honda Engineer about the P1K.
Mpmitch1
27
36
Madison
I've had the update even though I didn't think I had a problem. Post update my takeoff from standing still is much smoother and easier, it's not near as jerky or sensitive. Another difference post update....in between gear shifts rpms slightly rev up before the next gear engages. Before the update it was a quicker shift. Im not sure if the clutch update or the new oil the dealer used or the clutch reset changed this, but its different. Overall I'm happy with the update. ...especially the takeoff from zero.
