P1000 Clutches overheating
F
FloridaPath
70
210
Florida
So I went on 2ish hour ride. Lots of sugar sand so I had machine in 2wd and low for most of the ride. I noticed I started to bog down in some towards the end of the ride and switched to 4wd just to get through the sand then maybe 10 feet was on the road and took it back out of 4wd and into turf. A little bit after this just cruising down a hard packed trail next to the canal in low because I'm not going fast it suddenly seems like I am in neutral. I notice my warning light is on. After a second the machine starts moving and I go maybe 100ft to get off the trail and shut it down and let it cool for about 5 minutes then start it up and its fine. Was I doing something wrong? I am in swfl and it is hot. So hopefully the clutches are OK. First time I've had this light on and thought I should be in low when riding like this. I was only in 4wd for maybe 20 feet total. I did notice when I put it in 4wd to get out of the sand it was shifting kinda weird. So maybe just the hot weather?
hondabob
1,261
5,004
Prescott Valley, AZ
The clutch is slipping just below 2,000 rpm. In 1st gear that is below 3 mph in low range and 6 mph in high range. I doubt there is any clutch damage for some brief slippage.
F
FloridaPath
70
210
Florida
Thanks for the info! Have you had this happen?
hondabob
1,261
5,004
Prescott Valley, AZ
Two of the guys here bought the 2016 Pioneer 1000 for hunting. They spent a day driving mostly at 3 mph in high range. Honda did a good will warranty and replaced the burnt clutch. Many of the salespeople don't tell the customers about using low range at low speed. The clutch is so smooth you can't tell its slipping.
F
FloridaPath
70
210
Florida
But thats the thing I was in low for most of my trip.
Reactions: Remington
hondabob
1,261
5,004
Prescott Valley, AZ
If you are keeping the rpm above 2,000 and the clutch light comes on you may have another problem. 2 bars on the temp gage is normal. If you have it warmed good and turn it off just as the fan comes on in a minute or two you can get 3 bars by turning the key on but after starting it, it will go to 2 bars right away.
RedorDead
84
475
53
USA
At what speed, though? Well above 2,000 RPM, or just easing along?
Was it in first gear, or were you traveling fast enough for the transmission to up shift?
As a general practice, 4wd in sugar sand will strain less than 2wd. But as I’m sure you know, that stuff’s hard going when it’s deep and dry.
  • Wow
Reactions: Stevo and JenElio
F
FloridaPath
70
210
Florida
Yea thats why I had it in low 2wd. Maybe I will run in 4wd low when going through it. I was going fast enough for the trans to upshift. Except at the end when I had it in 4wd low because I was having a hard time. When I did that there was some weird I would say like shifting between gears it sounded like.
F
FloridaPath
70
210
Florida
I
You probably want to avoid the upshifting.
I was thinking if I was going fast enough to stay on top of it it would be better then going slow and sinking down more. If I keep it in first I will sink down more and be spinning more.
RedorDead
84
475
53
USA
The point of asking about upshifting was to indirectly get some sense of speed. I asked directly, but no answer on that. ;)
However I don’t really agree, if you’re going for instance in the 10 mph range, the trans control is smart enough to know if the load is lighter to up shift, and if you get deeper in the throttle to downshift. As it should.
I can agree that manual gear selection is the way to go if there’s an annoying amount of gear changing happening.
RedorDead
84
475
53
USA
I
I agree with you. Sugar sand is like running a boat in water, getting up on top and planing takes less power than plowing through it. The only thing I’d change is keep it in 4wd if the sand is that deep.
IMO sounds like you did nothing wrong, if you were going fast enough to stay on top of the sugar, you were way faster than 2,000 RPM. Could be an issue that needs further investigation by a good tech.
Addendum: just rereading your first post, when you say you bogged down. Do you mean you lost all momentum in 2WD and came to a halt, still into the throttle? That’s going to get hot quick.
115,707
@FloridaPath we have sugar sand all over our trails. Heavy tires and wheels don't help, also lots of air in tires. Not much u can do about that when u suddenly approach it. The other thing is when u get in it and your struggling to go, dont push it just stop and winch out or get some help, your bound to burn something up.
Just dont be this guy! DMPH!
right @trigger? 🤣
