P1000 Clutches...
popeye
popeye
3,275
14,644
kapowsin, Wa
Off road vehicles do not have to meet DOT safety guidelines, so they don't build them that way.
I figured that much after your response. But assumed because the cost of using a master cylinder resivoir that they allready had engineered for a civic or something similar and could possibly save lifes seems like a no brainer to me.
Reactions: JTW
275,307
Kind of surprising Honda didn't considering all the stuff they are proud about taking from the car division.
Ya, I was told by the man in the mirror that the wheel studs, tie rod ends, and tie rods are all essentially from an overseas model minivan, wonder if brake master cylinder with that safety feature is swappable too?
275,307
No argument here, since I could have been steamrolled when another P1k behind me cut his brakes going down Widowmaker hill. Had he not flipped over, he would have went over the mountain or slammed into me putting us both over the mountain.
322,773
Be an easy swap. To be honest there is some room there so this could be easily remedied possibly be taking it off and bringing it in and comparing. A lot of models are probably remotely close
Reactions: JTW
275,307
Just dawned on me, the LE models with I4WD and per wheel braking traction, wonder if that is a different master cylinder as it can apply braking to each individual wheel, not just both front, both rear, or all four together.
322,773
Good thinking
Reactions: JACKAL
275,307
Just got confirmation that the LE model brake master cylinder is different and like a common auto design with front / rear brake system split.
However do not know yet if easy or feasible swap, as in electronics involved or if it helps remedy should one line be cut.
lee
lee
Village Idiot
2,409
13,635
Springfield Ohio
Are you guys sure about this divided brake s***?
My Chevy truck had a rust perforation in one of the rear hard line last year (while I was on my way to ride at RRB).
Brakes went soft.
Then the low brake fluid light came on.
Then there was nothing.
Used the trailer brakes to get off the freeway.
Turned around and headed home adding fluid every time the low fluid light came on.
It was obvious one of the lines lost pressure.
Thought I could limp home but I didn't realize it would drain out to no brakes at all.
Trailer saved my ass.
Sounds like the P1k is similar.
Stop and fix it when you realize there is an issue.
275,307
Brakes went soft.
Meaning at least clamp off the leaking artery. Right?
322,773
However do not know yet if easy or feasible swap, as in electronics involved.
Any idea on how many lines coming out of it??
Anyone with an LE want to snap a quick picture?
Reactions: ohanacreek
275,307
I'm told the regular P1K is divided front/ rear, but LE is divided left / right. Not sure how that works out. If all fluid is lost still SOL.
Reactions: CumminsPusher
322,773
Brakes went soft.
Or ride it anyways because of the fantastic engine breaking. But I guess that shouldn't be suggested huh?
Reactions: popeye
322,773
Ask @Kilo427 How that worked out for him, or @Windrock1000.
lol! That wasn't exactly the spot for that to happen. I think someone could get down Widowmaker on engine brake but....
Reactions: JACKAL
275,307
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I'm doing a pinion brake. Got the rotor done and working on the caliper mount now.
IMG 20170528 150218584
IMG 20170511 194648394
