P1000 Squealing Clutches
Little_g
Little_g
404
660
Parker, AZ
I know it was abducted by the popos are there any signs of penetration maybe they implanted a belt LOL hahaha
My cousins wife said what’s wrong with his belt! :D
Reactions: BWAF
Little_g
Little_g
404
660
Parker, AZ
All I hear is the rear differential, check the fluid level. A few have had seals leak, even seen one running dry, it sounds like that high pitched squeal you mentioned.
Everything is good. No seals leaking or low fluid levels on anything. I am very anal about checking all my fluids before every ride I go on. Like I said I’m stumped and it seems to be a mystery. Hopefully it will eventually quit on its own.
Reactions: BWAF
67,646
I asked a few people for you. Didn't seems to know what it was.
Said it has to be something squeaking when the vibrations are just right.
Sorry, I know that's no help.
Reactions: BWAF and Little_g
Little_g
Little_g
404
660
Parker, AZ
Yeah it’s very strange. Lol. I appreciate the help and I appreciate everyone who’s had input and suggestions on this. We will just wait and see what happens. Hopefully nothing or maybe that’s how my machine is. As long as everything’s working I’m driving it.
Reactions: Plumber32 and BWAF
Kilo427
Kilo427
1,543
6,440
check below the air filter where it goes into the throttle body. There are very small screws holding that in that I have seen come loose two times. May it could make a squealing whistle sound if there is a small gap and its sucking air hard. If anything worth a check anyhow.
F
Farmoore
SEArkansas
My 2018 was making a god awful squeal from the front end while in 2wd and turf, I finally tightened the selector cable and fixed it.
Reactions: BWAF
Neohio
Neohio
Beast of the East
21,532
91,084
Painesville Ohio
Is it a mechanical squeal or whistling?
I think I hear the noise. but a 15 second video is just us grabbing at straws.
Can you replicate the noise accelerating slower?
Can you watch the Tach to see roughly where the noise comes into play?
What year is this? Any restrictions on intake tubing? Could be a loose clamp whistling under heavier load.
Very hard to differentiate between whistle and mechanical noise in your video.
Little_g
Little_g
404
660
Parker, AZ
This is coming from behind the cab right under the box.
Reactions: BWAF
Little_g
Little_g
404
660
Parker, AZ
Its a 2017 with the clutch update probably around 400 miles now. I can't quite remember. I'll upload a couple more videos I have and see if it will help you out any. It doesn't do it by just sitting in park revving the engine only happens when in gear and moving.
Reactions: BWAF
69,960
Sure sounds like it's sucking air to me.
Reactions: BWAF
Little_g
Little_g
404
660
Parker, AZ
Well I finally took it in to get looked at. Couldn't put up with that sound any longer. They said it was my muffler. The baffle came off/broke off or something like that. And as far as my heat shield that was upgraded or put on before I bought it wasn't on correctly and it started melting so I DK. Waiting on parts and should hopefully have it back next week. Thanks for all the help!
0860silverado
959
1,848
louisiana
Will your exhaust be covered under warranty? My muffler canister completely broke away from the exhaust pipe and I was told "things like brakes, tires, batteries, exhaust system components etc aren't covered under warranty". Had to buy a used one off of eBay for $175.00. My plastic cover melted too. I'd throw it away but my state registration sticker is baked on it.
Little_g
Little_g
404
660
Parker, AZ
Yeah they are covering it. I don’t see why the exhaust wouldn’t be??? I’d be checking on that one. Hoping that they can get the parts today and I can have it back for our ride this weekend. If not I’ve got my four wheeler but it’s not my pioneeer.
Reactions: 0860silverado
0860silverado
959
1,848
louisiana
Glad to hear they're gonna take care of you!
