P500 Day 1 maintenance
dtng
dtng
48
56
East Tennessee
So I just got a new P-500 and quickly realized that it was struggling to shift from 1st to 2nd. I noticed a number of folks stating similar problems and the fix seemed to be to adjust the clutch. I grabbed a 14mm wrench and short screwdriver and sure enough the problem was solved. So my question, are there any other adjustments I might need to check before I put too many miles on it?
34,173
It really makes one wonder about the made on Monday rigs, or why Honda’s quality control inspections seem hit and miss. For all the deserved criticism of Polaris, there seems to be a lot of Honda’s coming out of production with loose and missing hardware, front alignments out by inches :eek: and things out of adjustment. Supposedly Honda gives some attention to these various Honda forums???? Anyway, I guess mine was made on a Thursday. :D To your question however, many of the problems that people have encountered have been the result of bad dealer prep. If you’ll do a search, there is a thread or threads discussing the various things to be on the lookout for. Good luck compadre.
34,173
Grease fittings? A P5 has grease zerks? Have I missed something?!!!
Lol, it’s right behind your silver dollar sized spring loaded oil filter. :D
34,173
add grease to every fitting you can see, check the alignment, all the fluids, bolt check everything you can and give it just a good general look over.
I’m with AIR on the grease fittings, hope I don’t have a slew of bone dry zerks. ;)
11,304
83,938
Welcome. An old topic you may have already seen, but try to take battery /fuse cover off, with EASY torque on bolts as some spin from over tightening by dealer. A frequent issue. There are some pics down in this linked thread about the PITA keeper nut. Enjoy the P500. P500 - Caution on P500 battery cover bolts
dtng
dtng
48
56
East Tennessee
I don't doubt this was a dealer prep issue, but they were the lowest cost dealer by $500 which I'm using for some aftermarket add-on. So I'm guessing this is where they save money. Thanks.
dtng
dtng
48
56
East Tennessee
I was in the battery box the other day to hook up my winch, I had seen some of the comments on the bolts. I was lucky mine came on/off without any issues, I may epoxy the nuts in place. Hope to stay out of there for awhile.
11,304
83,938
Also the tire pressure can be too high from the dealer.
Reactions: Arizona and dtng
34,173
Sure, I understand that. Do check the threads that have chronicled the various issues members have had with their new machines, including things like Mudder mentioned a couple posts back and good luck with your Pioneer. :)
Reactions: dtng
11,304
83,938
Might be right, I run 6-8 in larger tires. Try adjusting for best ride.
Reactions: dtng
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
If you go into the battery box again, you might consider adding a battery tender to the P500....
