P1000 Decent cube lights
W
Weasel_master
27
32
Mn
I'm working on my dual battery setup so I can start wiring some accessories. Looking to add a backup light. I've got the soft rear panel so will probably mount the light to the roof. Trying to keep wattage low as I just need the light for backup, nothing special. What's a decent brand of lights that I'm not going to replace every 2 years when they get exposed to weather? I'm in Northern MN.
Reactions: TxDoc
W
Weasel_master
27
32
Mn
Thanks, forgot to look there. I'm going to get the Sirius light and mount it to the roof. Not sure the ROPS clamp on would work up high with the rear soft panel, unless someone here has done it already?
Reactions: Kinlaw
107,912
this is what have. There auxbeam cubes. Have had them since 16’ I call them my deer gutting lights lol. I have a soft rear panel i use from time to time and they work fine with that. If your mounting them high, any cube will suffice really. I also gave a link to the clamp below. They give you the length you will need to pass the hard top.
Auto Power Plus 1.75" Bull Bar Tube Mount Clamps Universal Mounting Brackets Holder Kits for Led Hid Light Bar ATV UTV Trucks Off-Road, 2pcs https://www.amazon.com/dp/B072J97YRN/?tag=sxsweb24-20
202BE866 C7AE 4287 856C 2CEA4E3929EA
Hillbillytnt
Hillbillytnt
521
1,922
Ky
I have a set of eBay side shooters mounted to the rear roof clamps with the soft rear panel. Mine is a three. Pros they are high and dry and light up the bed and sides Cons the bed casts a shadow so not good for lighting up the ground immediately behind you.
4838920D 99A1 4265 BF9B 7C36D2BBACE5
W
Weasel_master
27
32
Mn
Thanks for the help. With hunting and trapping season over I can finally go through and add accessories without worrying about my machine being out of commission.
Reactions: Kinlaw
