P1000m5 different snorkel types
Tracy12345
TX
$23 from Napa. Stock rough filter will push right in the end. Adds about 8" height compared to stock inlet and also moves it to a safe spot verses right up front where water can easily splash in....View attachment 45389
Sent from my SM-G920V using Tapatalk
How's this one working so far? It looks like you've had it on a while now. Any issues with water splash, etc?
Tracy12345
TX
I went the same route as @Macory. This was a good idea. Ordered the Gates hose from Amazon. They are up to $33 now. Picked up a pack of hose clamps from Advance Auto for $3. It took some effort to get the hose over the nipple but that's ok, it was a good tight fit. Liked about a 1/4" getting the hose pushed down all the way. Put the hose clamp on and stuffed the stock filter in the end. View attachment 56096View attachment 56097
Sent from my SAMSUNG-SM-G930A using Tapatalk
Seriously considering this. You still liking this setup? I'm also looking at the Snorkel Your ATV snorkel too.
urbancoyboyja
urbancoyboyja
Buckle Up, I Want To Try Something...
184
391
WV, USA
No complaints so far.
urbancoyboyja
urbancoyboyja
184
391
WV, USA
Just to be safe I put some holes near the end and put a couple pieces of coat hanger through it to keep the stock filter from getting sucked in.
Mjack138
7
Cincinnati, OH
  1. Talon X4 LV
I can out of air box into 3" tee then reduced to 2 - 1.5" flex pipes that come up each side of air box. Use 2" x 3" female coupler coming out of air box. Used dremel to grind inside out to 2.5" so no loss in air flow. Used warrior risers for a finished look. Pics are from mock up. I did add a 3" rubber connection between air box and tee to make easier to remove for maintenance. A little trimming to air box cover and front panel of bed to allow snorkel to clear and every thing works good.
View attachment 51524 View attachment 51525 View attachment 51526
Here is a little better pic of snorkel.
Hi, I know this an old thread but I like your snorkel. I was hoping you could send me a few more pics of the routing you used for each of the hoses and what you had to trim off to make it all work.
K
kyrider1000
68
220
Kentucky
I really like this setup . Do you still have a link as to what hose you got off amazon ?
Thanks
