P1000 DIY Skid Plate Template
N
njstang87
11
31
Indiana
Looks great. If you plan on riding any really rocky areas, I'd go ahead and put some angle iron on your side rails while everything is clean and straight
Do you happen to know what size angle iron is required?
Reactions: Lady01
62,931
2" x 2" x 1/4" works best. A 4' piece will do one side.
1618932199347
Reactions: Lady01
U
uggerud
minnesota
I would like to thank ctd power and bones for the files. I was able to locate some used uhmw from a local shop that installs it in semi dump trailers and dump trucks for free! I decided to just make it all one piece and made a front pair of front a arm guards too! I mounted the skid and still need to make the rear a arm guards and then get them mounted up. Thanks again guys!
View attachment 186134 View attachment 186135
can you get more i will pay the shipping to me
Reactions: Lady01
P
pioneerdoob
9
26
missouri
I see I'm late to the party again, anyone still have a copy of the .DFX file they'd send me?
Thanks in advance and thanks to @CTDpower for the original file!
116,574
[email protected]
Id take that email off your post. Scammers will have a field day with that up for the whole web to see.
just ask for someone to send u a PM on here instead.
roughrd00
30
51
az
Great job on the skid plate....Just wondering if you made any provisions for changing oils.....either a door, opening or do you still have to work around the plate.....
Ron
Rocksteady2246
Rocksteady2246
11
31
Ohio
  1. Looking to buy
Can someone PM me the template please and tank you
G
greidy78
Ontario
This is great work, thanks so much to all of you. I am lucky enough to have access to an entire metal shop. Anyone see a problem using 6061 1/4 " aluminum , I would love a copy of the template in DXF so I can cut it on our laser.. Could also waterjet UHMW if that would be superior.. Is there a DXF with the bend lines some folks have added?
Many thanks
JenElio
JenElio
82,558
716,525
Loxahatchee, florida
Many thanks
UHMW is the way to go if you ride rough/rocky trails a lot. I used the template and made mine out of 1/4" aluminum and it's held up great. I've only had it get hung up on a rock once in the 3 years I've had it. That being said, the UHMW I'm sure would slide way better over (everything) vs the aluminum.
20200519 221531
20200521 145002 HDR
20200521 202217
G
GolfCart
149
424
NH
I made skid plates using 3/16" 6061 aluminum on my previous sxs and they worked great. Tough as hell. They would hang up on rocks more than plastic however. So I put a lift kit on it. :p
