P1000 Do i need a tuner?
Rtcole
Rtcole
35
138
Arkansas
Thinking about changing out my exhaust on my 1000-5. Will i need a tuner? Recommendations for both exhaust and tuner if i need a tuner.
107,301
Negative, no tuner for an exhaust.
watch out when getting a tuner unless you know what your doing. Your changing alot of things in the motor From what its designed to do. If your not careful, you can have some serious and expensive issues.
use the search up top and use the thread loom option to look up tuners. Take some time and Read up before you just go out and buy One. You can do the same with exhausts. Theres been many installed and talked about on here.
PinchPerformance
PinchPerformance
Pinch, WV
I been using the Dynojet Power Vision 3, all stock. You can download tunes from their site. You can also use their Power Core software to custom tune.
HBarlow
HBarlow
1,614
5,997
Daniels, WV
A "tuner" is nothing more than a gimmick.
There are only two things a tuner can do - tinker with ignition timing or fuel injection timing and volume - neither of which is beneficial to your engine.
  • Haha
Reactions: Dezrik
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
What he said ⬆️ changing the muffler does more for sound than power.
What he said ⬆️ Dynojet Power Vision 3 is the way to go, also paying for a custom tune made for what you want to do will probably be worth it over a one size fits all tune.
If you think a tuner is a gimmick you need to widen your world view.
HBarlow
HBarlow
1,614
5,997
Daniels, WV
Please share your "world view." Explain what a tuner does - besides destroy a well-designed, tested and proven engine.
Engine manufacturers such as Honda with 100 years of corporate experience, millions of dollars worth of equipment, and a million dollar budget programmed their engine control computers to provide maximum performance within the parameters of reliability and durability.
Reactions: Remington
JMynes
JMynes
541
3,226
Augusta, Maine
I’ve had a tuner on a Harley Ultra Classic and a Winnebago (Ford V-10) motor home, so pretty much both ends of the spectrum.
In the case of the Harley, it was coupled with a bigger intake and bigger exhaust. It made a big difference in gitty-up, but you have to have more air flowing through the engine to burn more fuel and make more power.
In the motorhome it was mostly a case of changing shift points. The stock F-53 chassis has weird shifting habits, like a 5-3 downshift when you get to a hill. The tune let it go to 4th gear, which was way more pleasant.
Most manufacturers are tuning not for performance or durability, but to meet EPA regulations. The result is a lean running engine, which is better for the environment, but not optimal for either performance or durability.
If you want to play with your fuel mixture a tuner will let you do that. You might get a little more oomph out of it, but if you want monster power you have to flow more air.
158,264
^^^ Right there ^^^
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
What he said ⬆️
performance
All manufacturers try to make there products idiot proof with torque limiting tables, so between that and the EPA requirements there is room for improvement.
Just do a YouTube search like Honda Pioneer tuner shoot out, or turner test.
Anytime you modify your machine for more power your are generally trading it for longevity, driven with respect and it will live just fine drive like a idiot and you will destroy it faster directly related to the level of the modifications
Big power, takes big changes 💲💲💲 and a tuner.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
Here is a couple pictures of the tables that Dynojet identified this by no means is all that's going in the ECM.
Sorry about the crappy pictures the screen refresh rate and my phone don't get along. IMG 20220502 090100547 HDRIMG 20220502 090545719
Reactions: ToddACimer
HBarlow
HBarlow
1,614
5,997
Daniels, WV
A gasoline-powered internal combustion engine is basically an air pump. In simple terms, to make more power the engine must flow more air.
That can be done by increasing displacement - larger bore, longer stroke, or both.
Increasing air intake and exhaust output,
Increasing camshaft lift and duration,
or increasing combustion ratio.
In modern performance engines, a supercharger or turbocharger can force more air into the combustion chamber which is effectively the same as an increase in displacement.
The only things a tuner can do in an engine is tinker with ignition timing and fuel injection.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
I couldn't agree more with your post above.
After reading it I don't understand what your driving at?
Unless your talking about the PV3 which piggy back's on the injectors and coils you know the power vision 5 is not a gimmick so if you're digging for tuning tip here it is clutch pressure 😎
Sorry Rtcole for derailing your thread
I will embellish on what Remington posted you don't need to reprogram air fuel ratio for a muffler swap because a after market muffler isn't going to flow enough more to make a lean condition.
A cam change will perk a Pioneer up.
HBarlow
HBarlow
1,614
5,997
Daniels, WV
What I'm "driving at" is easy to understand.
The OP asked, "do I need a tuner?"
The answer imo is no one needs a tuner to tinker with ignition timing or fueling. If a tuner is desired to alter automatic transmission programming, that's a different issuer. The engine manufacturer programmed the engine management computer to carefully monitor and adjust those parameters for best efficiency.
What about that improved world view? I was hoping to be enlightened.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
Did you go look on YouTube see what can be gained by giving it a little more fuel and timing and clutch engagement?
There are more this is the first one that came up.
Is it fake? Is it a gimmick?
No parts changed just programming.
I give up.
john790
329
1,012
Clinton ohio 44216
  • Haha
HBarlow
HBarlow
1,614
5,997
Daniels, WV
Adding fuel to a modern computer-managed engine does nothing more than waste fuel and can wash lubrication from cylinder walls and cause piston ring wear, piston and cylinder scoring, and ultimate destruction.
A gasoline powered engine must operate at a ratio of about 14.7:1 air to fuel ratio to run efficiently and burn all fuel. That's known as stoichiometric ratio. If the ratio of fuel to air is increased the mixture is too rich and will emit black smoke, waste fuel, and wash cylinder walls. If air to fuel ratio is increased the engine will run lean, run hot, experience pre-ignition (spar knock), and can even burn a hole in a piston.
Varying in either direction from 14.7:1 causes power loss.
I cringe when I see men who know very little about engines buying tuners thinking they'll see increased power.
  • Haha
Reactions: Adam490
john790
329
1,012
Clinton ohio 44216
From the Honda engines i have worked on Honda leaves very little meat on the bone.Can you make a Honda run better for sure but usually requires replacing hard parts.Cams,Heads, Pistons,Turbos,Intakes,Exhausts, and they all must like each other.Now your tuner to pull it all together.
Reactions: HBarlow and Dave75
