P1000m5 Dual battery
So this brings up my question with searching for light bars on Amazon. I've seen a couple that are 900W, one even at 1080W. Can these huge amp draws 75A/90A respectively even be ran with a dual battery setup? I don't know how to figure out the max amperage a second aux battery setup could handle in total.
Or is something like that going to drain your system in a heartbeat and then the stock stator charging through a True Isolator never be able to keep it charged??
Trying to play an NFL game next to a NCAA FB game and only use the 1080W light bar?
Too much draw, you might be plenty happy with a 240w bar
221ec807b286736102eae15764ee10db
P1000m5 - The Mistress
Reactions: joeymt33
DmaxHunter
DmaxHunter
41
112
Northern AZ
Haha, yeah I figured anything that large would be overkill, but since I've never seen an LED light bar in person to have a baseline on wattage, I wondered what something that bright would really look like. I've seen a lot of pictures on here of different light bars, but it's still hard to gauge sometimes, and since I hear the watt ratings provided can sometimes be fudged pretty good, figured more couldn't hurt. That is until it becomes too much of an amp draw and the system can't keep up.
Thanks for the video, that really helps. Looks like sticking around the 300W will suffice.
I am curious as heck what a 1080W would look like though now. Might have to order it someday just for the heck of it....
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I went with the 500w and its bright, but not that much brighter than my old 240w was. If i could do it again I would have got a 300w. The extra 16amps isnt worth it IMO
Skyhawk85
Skyhawk85
6
6
Pulaski, Tennessee
Where did your dad mount his Blue Sea fuse block? I bought the same one & I'm looking for ideas.
Z
zin01
174
235
Royse City
Just a little personal info on the LED light bars. The wattage and all is good info on how bright the light bar will be but a lot depends on the LED placement in the bar and the cone shapes. LED don't naturally throw light very well. They throw less well then a normal bulb. If you look at the head lights on a delux model you will notice that they have almost magnifiers built into them to help throw the light. Anyway I am a. If believer in you get what you pay for with LED lighting if you want a smooth far reaching light bar look at the ridged industry light bars. They are expensive but the light you get out them are awesome.
What's your bargain brand choice?
Z
zin01
174
235
Royse City
I've ordered a few off Amazon that are not name brand just a good deal. I don't even know the name brand they are. As someone pointed out that if your trail riding you don't need light out very far. The ones I've ordered on Amazon work well and are by far cheaper honestly they all work well just don't throw a beam as far and as smooth as ridged.
Reactions: joeymt33 and JTW
39,079
Will the odyssey 925 fit as a replacement for the original stock battery?
I haven't tried it but it looks to be too big. You would need a different type of battery hold down even if it did fit in the cut out.
