P1000 Excessive turf mode use?
Bombardier Convert
Bombardier Convert
323
1,108
Minnesota USA
I only have about 85 miles on my '21 P1K-3 but I have been running in turf mode most of those miles. I have mainly been running hard packed forest trails, dirt roads, and some pavement roads. The reason for this type of use has been mainly because I just had back fusion surgery just under 2 months ago. About 25 of those miles were done before surgery. Anyway, is it possible to overwork the clutches and transmission if turf mode is used so much? Thanks!
208,011
I kinda doubt it.
Plowboy1466
Plowboy1466
289
1,437
Ashland, Ohio
Turf mode has nothing to do with the transmission or the clutches. It just unlocks the rear differential so both wheels aren't trying to turn at the same speed. I run mine in turf as much as I can to not wear out the drivetrain.
tbaker
355
595
NW. Georgia
How did your back fusion go I had 2 back fusions last year the last one was in November I am still trying to heal up they fused the last 2 disc at the bottom getting over back fusion surgery is a long slow process
Bombardier Convert
Bombardier Convert
323
1,108
Minnesota USA
How did your back fusion go I had to back fusions last year the last one was in November I am still trying to heal up they fused the last 2 disc at the bottom getting over back fusion surgery is a long slow process
This was the first back surgery for me. The bottom 2 vertebrae plus the big sacrum bone at the bottom. Two rods and six screews.. surgery went very well and pretty much took care of the stenosis leg pain I had for over 2 years. But recovery is very slow to heal like you say. I need to stay off the bumps on the trails for another couple months or so..
Dasmoeturhead
Good luck with your back. Sounds like your getting some relief. I fractured L1 & L2 and broke 2 ribs when I fell of a ladder 15 months ago. No surgery yet, cuz docs say there isn't anything they can do. It hurts like Hell when I bend over to do anything. Cheers!
tbaker
355
595
NW. Georgia
Yep I got 2 rods and 6 screws my self but the doctors think the bottom 2 screws might be loose causing me pain so they may take out the bottom 2 screws my bones have fused together so they want have to replace the bottom screws when they take them out I am ready to get over this I haven’t done much of anything the last year and my wife is getting tired of putting my shoes on she was putting on my underwear basically dressing me the last year have you started physical therapy yet and good luck and get better and be careful
Soaz1000
Soaz1000
157
852
Soaz
I've had two back surgeries the last one L4-L5 was fused. My best advice is to follow what your doctor and physical therapist says to the tee. Yes your going to get frustrated and it takes along time, but in the long run you'll be better off for it.
Don't be afraid to ask for help moving heavy items. Also using hand trucks become second nature. Good luck with your recovery.
Bombardier Convert
Bombardier Convert
323
1,108
Minnesota USA
Very sorry to read about your accident and injuries. Hope there will be something that can be done sometime in the near future to help you out. My back problem was just due to a lifetime of not taking as good care of how I used it as I should have. Lots of arthritis bone build up where the nerves had less and less room to move. Also had two bulging discs that didn't help matters at all.
Bombardier Convert
Bombardier Convert
323
1,108
Minnesota USA
I really know what you mean about needing help with doing almost everything. My wife has been great to be caring for me like she has.. don't know what I would do without her.. she has also been my best physical therapist I could ask for!
Bombardier Convert
Bombardier Convert
323
1,108
Minnesota USA
I use turf mode a lot too. Sometimes I forget and run up steep ditches to roads and am always impressed how much traction there is in turf mode.
I need to start using the paddle shifters, sometimes when going up steeper hills the automatic transmission upshifts at times when it probably shouldn't and it sounds like the engine is lugging until the transmission does a downshift, all in turf mode. I still haven't tried using the paddle shifters.
208,011
I was also very glad to read on another post about delaying the 100 mile first oil change. There is no way I would be able do that oil change myself!
BS, all it takes is a 10 & 12 mm socket, short extensions, 1/4 & 3/8 drives, funnel, oil & filters and rags. And a lot of patience, it's a pain in the butt. I suggest starting at the back with the engine and then the oil pan drains, then the filters.
Rayger143
Rayger143
2,712
23,474
Winfield, BC Canada
Absolutely. Awesome for downgrades too. Always use them in automatic mode. I barely use MT unless crawling.
Test - Grid
