I'll take that Mopar that's on the trailer....My first 6.7 Cummins was deleted with a different raised roof intake plate, heater delete, intake elbow and bigger inner cooler pipe. The delete came with a Smarty Sr. programmer good up to 175 additional hp. On the 175 hp setting that thing would fly!
This ole 67?I'll take that Mopar that's on the trailer....
Once you tow with a diesel, it's hard to go back to gas. Better fuel mileage and a lot less up and down shifting!Gas guy perspective and I admittedly don't understand half the details you guys are tossing back and forth. Bought a new 2017 Ford F250 6.2L Crew Cab couple years back because I couldn't pass up the price and gas has been relatively inexpensive. I get about 9mpg pulling 7k # travel trailer but figure I can afford to put a lot of gas in for the difference in price. I put about 10k on a year pulling camper, Pioneer and Harley around. Don't care for the constant shifting when pulling the camper so I usually run transmission in Tow/Haul mode. I know I won't have the longevity or resale but my big thing with Fords is the size of the cabs. They are huge and when you've got a some weight on it, it rides pretty good. I'm happy but good chance that my next truck will be a diesel.
Is that a 305ci?This ole 67?View attachment 242483
305, no it's a 496 with a little boost!Is that a 305ci?
You will pay more for the FASS, the owner of Airdog used to work for FASS. Our youngest son bought an Airdog and has had zero problems. Between an Airdog and Airdog2 would be up to you. Don't set fuel pressure over 15 psi if adjustable. FASS or Airdog either one would be light years ahead of the factory fuel pump, plus a lot more filtration.Quick question, I am thinking of getting a lift pump. Should I get Fass Signature, airdog, or airdog 2? Still messing with the injectors. It should be done tomorrow. The old are out and new are in, went ahead and did lash on all rockers, next is to put the valve cover on and connect fuel lines.
New as in 10 years agoNah, sometimes it's hard to keep up with all the new meanings.
CP, What’s the deal with the DEF. I see “Blue Def” and its 16-18 bucks, I see some off brand at Tractor Supply and it’s 6.95?????I’m right there with ya. Curious to see just how dependable the new trucks are in 25-30 years like some of the proven ones are now. Probably on my last truck till diesel fades to electric (I’ll go down fighting lol) no more payments.
I don’t want to put junk in my motor, but is there really a difference?
It is very corrosive, in a Ford you basically replace the whole fuel system, injectors and all.And don’t accidentally put it in the fuel. Heard of a few people doing that. Very expensive lesson
