L
Hi.. we have a 2019 Talon X.. Have had zero problems until now.. Hubs installed a 12 v fan yesterday. Made lap around yard after finishing to check out air flow.. worked fine for about 5 mins & then started dying every time he put it in gear. I have read so much the last 24 hours, and everything seems to go back to loose ground.. the fan was ground to the frame & wired to the hot.. He removed the fan & it is still doing it.. It has the clutch light flashing constant & E flashing in the gear light.. It is flashing 3 slow, 2fast as soon as it dies. As soon as he turns off key & turns it back on, flashing lights are gone & it appears normal, until you put it in gear and it dies again..Dealership isn't open for 3 more days & we have a big trip planned in 5.. Thanks for any and all help!!
