P500 For Sale: Rubber Noise/Heat Shield
Mudder
Mudder
NTC/TAP Transition Member
11,865
90,386
Only note is that you may need to make an additional slit for whichever rear panel brand you have, and how you care to run it. Easy trim with scissors given I have the OEM panel with those two small velcro straps. Good that it comes generic to minimize unnecessary cuts.
Reactions: trigger
195,109
Yeah, I'm cutting them for a base P5, not each individuals set up or accessories. I have cuts in mine for the snorkel and wiring that wouldn't apply to someone else's machine. I'm also not poking drain holes into these as they may sag different in someone else's machine. After a wash or deep water crossing look to see where there might be water puddling on the shield and poke a couple of drain holes. I have two in mine. ;)
snakeriver
272
596
Clarkston Wa
Hey Trigger I just got my sticker, I certainly did not expect you to send me one after the fact. Just a great example of your customer service excellence. I am usually not a sticker type of guy, but I will run this one with pride. Thanks for all you do.......
RDRC
RDRC
40
70
Colorado
Hey Trigger add me to your list for a shield. I am currently using foil material that is similar to the automobile sun shades for heat reduction. It works for the heat but not for the noise.
Reactions: Eltobgi and trigger
195,109
No, thank you! You bought one and I'm happy to send the little token that goes with it. Didn't start making these for a boat load of money but I am getting rich by the camaraderie and satisfaction of helping others out. A handshake and a smile if we ever meet up is all I ask in return... unless I'm stuck in a mudhole...:D
Nashby
Nashby
75
285
53
83644
Before I got my trigger Shield I looked at some pictures of people who had already installed one on there machine. I almost didn't order one because it looked like it was more of a grayish black then straight black. Things not matching bothers me, so I was thinking of just making my own. I ended up ordering one anyway and this is what I realized. The rubber comes with a powdery residue on it that makes it look lighter in color. Before I installed mine I gave it a real quick washing with a soap and rag, dried it and then sprayed it with WD-40. Then I wiped off the excess WD-40 and Wallah perfect match. So, basically what I'm saying is if you're like me and noticed the color difference don't let it stop you from ordering one, it's not a big deal, just wash it spray it and install it. Total it only takes 15 to 20 minutes.
Useful information, thanks for sharing.
195,109
Yes it does have a powdery residue. That's coming right off the roll that way, without it would stick together and be a pain to unroll. I saw it and considered wiping them down but after you ride with them they get pretty dirty anyway. You'll be surprised how much the underside gets dirty, it blocks mud too. Mine's been through hell and isn't brittle in any way, maybe a little stiffer and form fitting. Oiling it is a great idea for taking care of the rubber though.
Husker1
114
186
Nebraska
Rubber roofing is extremely tough. We would make a small hole in it and could stick a 4” pipe through and not tear it. Thanks Trigger if you’re stuck in a mud hole I’ll still help and shake your hand.
jrplaza2008
jrplaza2008
677
2,147
Richmond, TX
@jrplaza2008 knocked it out of the park again! What's ironic is that I have a sign and graphics company right down the road from my house that I've done business with before on construction projects. He (Walter)just knows the look I'm after without saying it and isn't offended if I want to make subtle changes to the design. Good man and easy to work with! Might not be the cheapest but the good sh** never is. ;)
Thanks Walter and nice work as usual. :cool:
Always a pleasure my friend! Thank you for your kindness and for your business!!
snakeriver
272
596
Clarkston Wa
Any time buddy!!!!!!
Shadesmn
Shadesmn
505
959
Ramsey, MN
How long is the wait list currently @trigger? I have.buckets so the heat isn't much of a problem anymore, but noise is still a factor. Possibly worse now with less solid seat covering the bottom..pondering about one now after following this thread since it began...:D
