P500 For Sale: Rubber Noise/Heat Shield
snakeriver
272
596
Clarkston Wa
Please keep in mind that I have not done any cleanup on this so you will see some glue residue. Also on the bottom hole I did not get it quite square but it works just fine. (i may have test drove it to soon) Sorry about the sideways pix, but I took them at 5:00 AM this morning in a dark shop.
Reactions: trigger
194,701
No pics came through.
snakeriver
272
596
Clarkston Wa
OK lets try again
20201105 063802 20201105 063812
snakeriver
272
596
Clarkston Wa
I used silicone at first but it did not really work well, the next thing I tried was 3m trim cement and was not really happy with it. However Gorilla glue seems to be the bomb.
Reactions: Mudder and trigger
211,660
To be the Bomb? You must be old! I used that phrase couple years ago with a friend/customer and he cracks up, said he hadn't heard that description in years, now when we talk, it's always about the bomb! HA!
194,701
Damn, that's permanent now! I suggested silicone so it could be removed if necessary, though I don't really know why you'd need to remove it? I've sent out about a dozen of these now and haven't had any negative feedback. I hate making the one but I guess if guys want them I'll make them. Been selling them with the shields for an extra $20.
Reactions: Mudwing and Mudder
snakeriver
272
596
Clarkston Wa
[/QUOT
Best bang for the buck that I have spent...
Reactions: trigger
RobbieS
RobbieS
78
163
Pagosa Springs, Colorado
Hey Trigger, bought mine a while ago and don't remember, you say " Been selling them with the shields for an extra $20.", did I get a shield with mine? Not sure of what you are referring to. Love the mat, keeps out the dust, noise and heat. And don't remember paying you and extra $20! ???
makac132
makac132
59
155
Nelson, B.C.
As anyone who owns a P5 knows, the noise that comes from behind you is loud. Especially with a roof and windshield on, it just reverberates off of them. Another issue is with the heat that comes up between the seats and the seat belt latch area, just ride through a puddle with a hot engine and watch the steam roll in.
3 yrs ago when I got mine, the fix was to buy some foil backed carpet to put under the seat. It was like $38 for a 3' x 4' piece. Wasn't quite enough and didn't cover it entirely but it worked pretty good. The problem was that it was carpet in an off road machine, always wet, hard to clean and started to stink.
Had an idea to use commercial roof rubber instead, thin so it conforms but tough and doesn't break down. I've had it in for a couple of years now. It's works better than the carpet because it's heavier and I never take it out unless I need to get underneath. First time taking the seat out after a pressure wash, I found two little pockets where water had puddled, cut two little holes and it's always dry now.
Evidently this rubber is hard to find in small quantities and expensive. The cheapest I found online was $100 for a 10' x 10' sheet. Then you have to cut it which is a total PITA! I've cut 4 of them now, using each previous one as a gauge and it still sucks trying to get it perfect. Too many contours for it to lay perfectly flat but it's sealed up good.
I think I have a good enough pattern now and enough rubber to make a batch of these for sale if anyone is interested? It would be $70 shipped.
Here's what you'd be getting, less some of the cuts for snorkel and wiring...
View attachment 105219 View attachment 105222 View attachment 105223 View attachment 105224
