Mention how many people flipped if running more then one person and show her thisView attachment 43110
Think he used that excuse for brake lines already lolMention how many people flipped if running more then one person and show her thisView attachment 43110
So if I am understanding correctly - you2 1/4 from housing to upper nut in front. I'm heavier then most though. Rear left alone so far it's been great but only running three people in front so far. I'll get this in this weekend
Ya that's a good reference for sure. Obviously weight matters. There should be about an inch of sag to the shocks at rest with normal load reguardless of where the rig previously sat. My rears came out of the box with just a little more hight in the rear and less in the front then stock but I'd say they should be about a 1/4 higher all the way from what I seeSo if I am understanding correctly - you
1. Settle the shocks and measure the height from the floor (from a specific reference point)
2. You load the weight into the machine that you normally ride with (including yourself and passengers
3. Adjust the shocks (to compensate in drop in height) to where the original height / clearance with out passengers is the same with the weight added?
Does this sound right?
My front sits a little lower than the back now. I have not added a Bumper but have added a winch and extra battery up front. I was surprised to see how much more adjustment was in the fronts of the PK-3 verses the Pk-5. I know @Tigermark 's front shocks were dialed down further than mine and while I know the PK-5 is heaver I would not have though all that weight was in the front.Ya that's a good reference for sure. Obviously weight matters. There should be about an inch of sag to the shocks at rest with normal load reguardless of where the rig previously sat. My rears came out of the box with just a little more hight in the rear and less in the front then stock but I'd say they should be about a 1/4 higher all the way from what I see
The shocks for the two are different. I was surprised at how high the springs for the 5 sat and I'm positive that's not enough spring rate for anyone. Turned out costly for meMy front sits a little lower than the back now. I have not added a Bumper but have added a winch and extra battery up front. I was surprised to see how much more adjustment was in the fronts of the PK-3 verses the Pk-5. I know @Tigermark 's front shocks were dialed down further than mine and while I know the PK-5 is heaver I would not have though all that weight was in the front.
Thanks for info just ordered some todayView attachment 43106 This one works well
Inch of sag please explain.? Have mine on orderYa that's a good reference for sure. Obviously weight matters. There should be about an inch of sag to the shocks at rest with normal load reguardless of where the rig previously sat. My rears came out of the box with just a little more hight in the rear and less in the front then stock but I'd say they should be about a 1/4 higher all the way from what I see
When you ordered your Elka's did they ask you what assessories you have? I think Elka tries to get you close to the right set up out of the boxOne thing I like about the elkas. No spanner needed. Those things suck. Allen clamp screw and a round rod with a 45 to turn the nut. No beating with a chisel!View attachment 42931
Yes. I did send them back for a re-valve though.When you ordered your Elka's did they ask you what assessories you have? I think Elka tries to get you close to the right set up out of the box
Why?Yes. I did send them back for a re-valve though.
Wanted the low speed compression softer and added rear rebound.Why?
Do you have a copy of the service order? Sounds like the set up I want.Wanted the low speed compression softer and added rear rebound.
Yep. Have all the stack specs F & R before and after. Still needs a little tweak but pretty close. Remind me Monday and I'll shoot them to you.Do you have a copy of the service order? Sounds like the set up I want.
ThanksYep. Have all the stack specs F & R before and after. Still needs a little tweak but pretty close. Remind me Monday and I'll shoot them to you.
