P1000 Fox vs losd leveling rears.
Brentc
Brentc
71
67
SE AK
Im getting foxs for the front but not sure about the rear. Can the fox's hold as much as the load leveling shocks? Plan on hualing in camp gear and hopefully a moose. My neighbor was really impressed with the load levelers. I will say fox's were a game changer on my 700-4. Thanks for any imput.
Reactions: sharp and BWAF
322,690
I thought the same at first about keeping the levelers but that lasted a day day with fronts in. We’ve had a few pretty good loads with Fox and the do well it just sags a bit more under very heavy loads.
Reactions: 100Acre and BWAF
Brentc
Brentc
71
67
SE AK
Thats the problem clearance is already scarce on some of these trails would preloading the springs for height for a trip ruin the springs? I know the ride will degraded but its 10-14 days of supplies for a trip in and out.
ToddACimer
ToddACimer
Pioneer 1005-2
3,676
15,543
Oshkosh, Wi
The fox shocks will ride better at any weight than the load leveling shocks if preloaded correctly. I rode my machine once with Front Fox shocks and stock rear it sucked. Once you pull the rear shocks you can eliminate the rear wheel hop and start to enjoy the machine .
322,690
Ya well a lot of people want to say something but there are a few that can tell you the truth. Everyone has there own decisions but that’s not this group lol been there done it;)
F27DE587 66C8 462F B5FC EA442D0132D6
322,690
You sure you have enough loaded in there I think I still see room............for one or two twigs. Lol
We’ve done that a few times. It’s a heavy load with either levelers or Fox. It’s fun to roll back to camp loaded but it’s tough to pull out of the woods, steering is a little light with tailgate loaded too
322,690
Cumminspusher is that with fox's?
That picture was not she was stock. I thought I had taken a picture with the Fox but can’t find it. It handles close with weight but does sag a bit more. Most loads I’d doubt you’d notice a difference.
If I were to be hauling all the time I’d leave factory and the sway bar alone. But if trail running most the time shocks are worth it.
Reactions: BWAF
Brentc
Brentc
71
67
SE AK
This was my 700 with fox's only adjusted the valving not the preload. Wood was kind of wet i usually cut wood when its raining and split on sunny days.
17648 aceb7613ed438da5968c12645240f257
208,726
I try not to load my tail gate until 2:00/3:00 AM and unload Sun up! HA!
