P1000 FYI, Honda responce to heat problem
George201074
George201074
14
Ohio
I have installed the blower and the insulation under the seat. Heat is still unbearable while driving more than 20 minutes @ 10mph or slower. I have owned gators, artic cats, pioneer 700. Never had a heat issue before I bought the 1000-5 deluxe.
Seriously? Mines not bad with just insulation. Bearable at 20 and below atleast. Dont get me wrong it's no car with ac tho. Lol
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I installed 2 blowers and insulation under the seat... these mods completely resolved the heat issue. I creep along under 10-15mph most of the time, and its been 99degrees here lately. I'm not sure if I needed 2 blowers, but they don't cost much, and I really wanted the heat issue resolved!lol
Riverrat
Riverrat
86
234
UP of Michigan
Do you get much noise from the fans?
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I wonder why the blower and insulation solved the issue for myself and others, but not for you...?
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
the insulation under the seat helps knock the noise down, but yes, you can hear the fans. once the engine is revved up and running through the gears, I don't hear the blowers, but I do hear them when I stop.
N
Ned
241
183
West Kentucky
I have one and can absolutely see that 2 could be better. After riding some last night, I shut down my machine and left the blower run for a few minutes to carry away some heat. When I was behind it on either side I sure could feel the hot air being blown out. I don't think two would be over kill and once summer is over, out they come. I also like the manual operation vs a thermostat. I start the blower sometime before I get too much heat built up if I expect to be riding long and slow. In 95 degree weather, once it's hot it is much harder to get cool.
Reactions: Everett and Stauvo
Riverrat
Riverrat
86
234
UP of Michigan
Thanks for the reply. I wonder if fans will be part of the Honda fix?
322,675
I truly doubt it. It will be insulation and a a cover. Maybe they will call it the "warm weather package "
Reactions: JTH and joeymt33
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I definitely agree about the manual switch, and was excited to feel the heat being blown out the rear too!
I used a 4" fan and a 3" fan. The area where the 4" fan blows is open all the way to the back of the machine, but the 3" mounted under the drivers side of the seat pretty much blows right into the motor. There is a little space between the motor and the seat, so I'm sure there is some air blown through that side too, but I figured 90% of my benefit is coming from the 4" blower mounted under the passenger side of the seat. That's the one that blows across the exhaust manifold and down the full length of the exhaust pipe.
Reactions: CumminsPusher
ghost
ghost
993
1,873
BC
Windshield ?
Read panel ?
ibleed is getting heat from from the dash.
Did you insulate that red-hot black plastic between the upper and lower seats? I did that first - but maybe not needed if blowers are running.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Any more pics of blower install sites? Trying to see exactly where everyone has them mounted. I expect to be off 4 days next week and intend to install mine. I've got PioneerPetes printed off lol.
322,675
So like many others I called and talked to Joe at American Honda and he was real understanding about the heat problem. Ask me a couple questions and has the "evaluation kit" being sent to my dealer right now Said it's designed to kill off the heat and dust which makes sense. I was going to wait to see what others felt about the kit but I figured I'd order it and if I don't like it I'll pull it out if I do need heat back.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Is the dealer gonna have to install it? Hate to take mine in just for that. There are a couple mods I'd rather they not see on mine lmao. Luckily they are all reversible
322,675
Yep! I tried my damnest to try to get them to let me take responsibility for the kit or at least send it to my Friend with a Yamaha dealer but not a chance! Sucks! If you're worried about your snorkel it should be fine that's what I was told multiple times and even had them make a note of it.
sharp
sharp
3,757
14,955
Tennessee
Heat problem solved!
George201074
George201074
14
Ohio
Awesome do you think a small fan from autozone would work?
ibleedjohndeeregreen
62
62
Iowa
I don't know why but I would sure love to knock down the heat. I am considering adding a second blower under the seat. I am not expecting air conditioned cab, but like I mentioned before I have owned numerous sxs including the pioneer 700. The heat from the 1000-5 deluxe is by far the worst. To the point people refuse to ride in it
Reactions: PioneerPete
