got my purty red foxes for the front. How much preload are you guys running? Leave at factory setting?
Proper shock nut torque?
Thanks
Just get it out and ride it and make adjustments depending on the feedback you receive. If you want the shocks to be a little bit stiffer, turn the preload down some as that will increase the spring rate. It will also increase the ride height a little bit.
I will often adjust the preload in my shocks depending on amount of passengers or cargo. Recently on a camping trip I turn the rear shocks four rounds of preload. Next time I go on a ride alone, I will take those four rounds back out.
