Talon GPS/Tablet Mount
K9Paco
K9Paco
619
2,155
Lake Charles, La
  1. Talon X LV
Hi,
I thought sharing my setup as I got inspired by some of the posts here:
Im using a Samsung tabA 8” for the gps chip and decided to go with an Otterbox Defender case (as I found a refurbished- like new for 12$ instead of 69$) over an Akron adhesive and ram mount. I glued the Arkon directly on the outside case
I will see the long term durability but for now, its working good and offer a “lean” look ;)
Cheers,
View attachment 266345View attachment 266346
View attachment 266353Links
Otterbox box :
OtterBox Defender Series Case for Samsung Galaxy Tab A (8.0-2018 Version) - Retail Packaging - Black, Model Number: 77-61125 https://www.amazon.com/dp/B07JN2R4P7/?tag=sxsweb24-20
RAM 1 inch ball mount:
RAM Diamond Ball Base https://www.amazon.com/dp/B002KO5XVU?tag=sxsweb24-20
Ram small double socket:
RAM Composite Double Socket Arm https://www.amazon.com/dp/B005KWPJ04?tag=sxsweb24-20
Arkon adhesive base:
Arkon 70mm Extra Strength VHB... https://www.amazon.com/dp/B01MRT7KCA?tag=sxsweb24-20
I also put my 8” Tab A in an Otterbox Defender case. Then I hot glued the holes that expose the tablet. You can still take it out of the case with the glue in place.
Reactions: CID and TripleB
rustyneversleeps
rustyneversleeps
381
1,833
Montana
Hi,
Cheers,
Otterbox box :
Curious how this setup is holding up?
deltajp
10
19
Huntington Beach, CA
Functional and economical - a buck or two for sticky-backed Velcro.
20211124 134240
20211124 134409
20211124 134228
Reactions: stellarpod and CID
