P1000 Has anyone had they're brakes fail?
E
Everett
20
17
I was on Mt Antero last weekend at about 12000 ft coming down when my brakes went to the floor. Had to pump brake pedal four times before pedal came back. This happened twice in a short time then they worked good again. It was not a good time for this to happen. If it would have happened a few minutes earlier we would not be here. I'm going to talk to Honda about this in the morning. This is not a good thing since these do not have a emergency brake to fall back on. When this happened we had no brakes at all on a real steep grade and hairpin switchbacks with several thousand ft drop off. I'm just reporting this so hopefully everyone can be prepared if you have this happen. Will report back on this issue after I talk to Honda. Hopefully they replace master cylinder. I checked for leaks but all looked good.
39,079
That happened to be several times in the first month or so of owning my pioneer. I have no idea what caused it. I thought about contacting Honda but I couldn't reproduce the problem so I never did. I've got 1000 additional miles since then and it's never happened again.
Reactions: CumminsPusher
Riverrat
Riverrat
86
234
UP of Michigan
Interesting, my p1kd brakes sometimes will go all the way to the floor, have to pump them 2 or 3 times and they come back, but sometimes very scary like coming up on a corner of a busy road. Please post what Honda has to say.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Mine did it and I found a leak on the back driver side the bolt that holds the brake line on was leaking I had to tighten it then bleed the bakes.
E
Everett
20
17
Thanks for the replies. I'm going to clean it up and check all lines and connections when I get home this weekend. I called customer support but they were no help.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
sounds like cause for a good brake bleeding. I recently installed a line lock on my front brake system and bled the brakes afterwards... they worked better than before, so I'm guessing I may have had some air from the factory.
E
Everett
20
17
Yes I plan to bleed the system after I check lines and fittings for leaks.
Reactions: dotman1
63,542
@Everett,
- Do you have any a-arm guards?
- What wheels and tires are you running?
Asking because someone.... I thought it was @joeymt33 but guess not since he did not mention it.
Well, they had a-arm guards and were running wider than factory tires. If they did not use the brakes for a while and this same thing would happen. At some point, they noticed the arm guard was rubbing. After they trimmed it up it stopped loosing pressure. Discussing it, the guards were also pressing against the caliper making the piston push back in just enough.
39,079
@Everett,
My problem could have been related to the banjo bolt hitting the A-arm after the arched arms were installed. Even though I never saw a wet spot that would indicate a leak.
499ff46ab237f134ce444c33ccd040ca
B8db8c6526d665de9980246090bd3ba1
I never mentioned it because it was isolated to early in my ownership and only several short times. I thought it may have been because of air in the lines. Guess I'll never know.
Signature:
QUOTE by Tflynn, "The aftermarket doesn't build what you want? Show them your favorite finger and build it yourself!"
E
Everett
20
17
I have not had time to check lines and connections yet. Been too busy. Hope to have time over the weekend. Yes I have A-arm guards (Honda) and stock tires and wheels.
Kilo427
Kilo427
1,543
6,439
Same with me I installed a line loc and bled them seemed to work better than before.
Reactions: PioneerPete
How does this line lock work and where are you mounting it? Anyone have a build link?
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
There are some installed pics in my garage photos. It taps into the front lines at the master cylinder.
Reactions: JTW
Kilo427
Kilo427
1,543
6,439
I would use a manual one like his vs the electric one like mine fyi
Reactions: JTW
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
Thanks.. I shouldn't have looked thru all those garage pics! That's exactly the direction I plan on going with everything!
If you are interested in the brake line stop, I can get you some more pics of the tubing that needs to be made up and where to connect it. It's very simple and effective.
Reactions: JTW and AKRider
Whenever you have time.. I'm out of town all week. So no hurry.. but this is most certainly something I'm interested in doing.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
sorry @JTW I don't recall getting a notification for this post, so just now seeing it. I'll try to get some pics for you this evening.
Similar threads
