anyone ever use this heater.2016-2018 HONDA PIONEER 1000 INFERNO CAB HEATER with DEFROST (HIDDEN DIRECT-FIT)
Looks like a well thought out design, wouldn't work for me, I've got a switch panel where there defrost vents are.anyone ever use this heater.2016-2018 HONDA PIONEER 1000 INFERNO CAB HEATER with DEFROST (HIDDEN DIRECT-FIT)
Half the heat is lost on the way to the vents. It runs under the floorboards and by the time the air comes out the dash its luke warm at best. A relative had one. I would shoot the heat out right under the seat. There are four ports. Two of them come out the front of the engine compartment below the seat and the other to travel through the tunnel up to where most people mount a switch plate. You can close the vents.I’m planning on cutting my switch plate in half so that I can have the vents above. I’ll put a voltmeter somewhere else and I really don’t have any use for three cigarette adapters.
Just get some heat proof tubing and wrap it around the headers! HA!Thanks for the tip. I was thinking the tubing was quite thin for how far that air has to travel. I have A roll of insulation and was thinking of wrapping the tubing the travel through the tunnel in that.
That's where I'm headed.The first thing I did when the weather started to get cold was takeoff that cabin comfort piece of rubber. Warmed it up in there about 10°.
What kind of insulation? Foam is the only option. Fiberglass will get waterlogged and become a mess.Thanks for the tip. I was thinking the tubing was quite thin for how far that air has to travel. I have A roll of insulation and was thinking of wrapping the tubing the travel through the tunnel in that.
Yeah, but Smitty.......Looks like a well thought out design, wouldn't work for me, I've got a switch panel where there defrost vents are.
Yea right! HA!Yeah, but Smitty.......
From his link: “We bring in each machine and customize a heater that fits ONLY that machine”.
Connection at radiator is 1". 27mm at the largest part of barb.I turned my bilge fan around today and have it ducted into the footwell, it helps on the moderate days. I am wondering if any one knows the ID of the radiator hoses? I know @Delton had asked a while back. I have a heater box I bought for a previous box truck and I plan on installing it in the footwell. It will eliminate the foot space for my center seat during the winter, but we typically only use that for a 3yo in a car seat anyways. It plumbs into the coolant system and has a radiator and 2 speed fan. I will post a couple pictures tomorrow.
