P500 Help With Diagnosis
futzin
futzin
4,814
35,325
Kentucky
I took a short video of me working the steering wheel back and forth slightly with the key off. You can definitely feel the steering hitting detents at least once each direction; not smooth. In the video, I exaggerate it a bit to illustrate. I'll see if I can get the video up. Busy day today so we'll see.
[/QUOTE]
212,729
[/QUOTE]
You need someone watching the front end when you do that.
futzin
futzin
4,814
35,325
Kentucky
Starting Monday (maybe Sunday afternoon) I'll start tearing into the 500 to look for bent/wonky pieces. Since it's entirely likely that I'll look at a bad part and not even know it, I'll use (and tear into as necessary) the 520 for comparison. I may even install 520 parts on the 500 if needed.
Time consuming, but probably a good way for a mechanically declined guy like me to go about it.
I figure the toe out issue will be easier to ID than the steering issue. But both buggies have the same stuff (excepting the shocks) so hopefully that helps me. Hoping for a bent steering shaft or linkage at this point really.
Dreading it's a rack issue . . .
For the shock experts: did I read somewhere that too much preload can result in excess strain on the ball joint?
196,374
Well I'm far from being any kind of suspension expert and only know what I've experienced on my machine. Based on that, whether it's the stockers or aftermarkets, too much preload on the P5 just causes problems in general.
Fatsquatch
Fatsquatch
Approved Member
121,567
1,013,438
Hidden
Got em jacked up, rt front wheels off.
View attachment 401109View attachment 401110
The only thing I see thus far is a bent a-arm bracket: upper arm, rear bracket.
If the paint isn’t cracked anywhere there and welds look solid I’d be willing to bet that bracket was tweaked in from tightening the A arm down at the factory. Just a guess from this particular pic though. You can make a better judgement call being able to see all the way around both sides of both A arm mounts I’m sure.
212,729
Ball joint too loose, I think
The P1 & P7 has a grooved steering shaft coming out of the steering box, the bottom universal pinch bolt needs to be in that groove, you may have to loosen top universal pinch bolt to get the bottom pinch bolt to rest in the shaft groove. Throw the bolt away and get a new one. This was a recall on some of the early P1's. Anyways match bottom pinch bolt of the universal to the steering box shaft groove then tighten top universal pinch bolt on to the shaft coming from your steering wheel. I would think the P5 would be the same as other P's. Now on to the ball joint, did you check it with the tire on? You won't be able to get enough leverage with the tire off to check unless it just falls out. Please keep us apprised.
212,729
The ball joint feels fairly loose/pretty easy to manipulate, notchy . . .
Hopefully that and the steering knuckle are the issues. I'll bet there is a You Tube Vid of the process, You will probably need access to a ball joint removal tool ( $25.00 OR LESS AT HARBOR FREIGHT) and a press to install new ball joint.
21,761
93,349
Order new hardware for your steering joint. I think new bolts are less than $1 ea.
I completely lost steering on mine during takeover. We tightened it up enough on the trail to make it back to RRB, then swapped with a bolt for remainder of week.
