P1000 Homemade Door Bushings
175
493
Kansas
Did anyone mic the pin? I forgot to grab one at home today. or if I drill 5/16 it will be fine. Drill undersize and ream. anyone up for some blinds darts?
All of your dimensions will work fine. 5/16 is perfect for the pin and the hinge support can be be manipulated a bit to relieve or tighten the fit on the bushing if need be.
I didn’t use any sort of lubricant on mine and they swing freely with no binding whatsoever.
Reactions: BWAF, sharp and JTW
320,147
I actually believe lubricant on some things to be bad because it attracts dirt. Learned that from dirt bikes, especially on brake throttle and clutch cables.
320,147
Well-- I have a ton of these things. Pins get a little too snug for comfort halfway down the hole so I am going to ream them "quick."
Oh man that’s set up for @JTW
Hey @OleRed thanks do much for your intent, that’s very generous!
O
OleRed
142
275
One fella sent me message saying he would distribute them... I suppose I should send half one way and half another. Not sure who is closest to the main vein but they can go today if I get them all reamed. Monday latest. They do fit snug in the bracket and snug in the molded hole on the door. Good measuring by CU.
Send half to me then at the address I provided yesterday and half to @Hondasxs to distribute at the Takeover, I’ll cover postage to mail sets to members that would like to have them that can’t make the Takeover.
