P1000 Honda Pioneer 1000 Clutch Replacement - A How To Guide!
Cajun-Abear
Cajun-Abear
49
141
Louisiana
Yeah, the gear has a couple holes in it. I use a small screwdriver to align the geara nd then a bolt to hold it in place. Slide the clutch on and then remove the bolt.
Its the reason the entire back half of the engine needs to come off to install a Pioneer clutch.
That makes a difference. In your first post about this, you state that the 6mm bolt is for "tension" on a gear that the clutch rides against. If the bolt is only for "alignment" and you can install the clutch back into place without it, I don't see where the bolt is necessary. Just a layman rookie's opinion, though! @P1K5Dave I think I got mine back in on the second attempt!
The gear is actually a 2 piece scissor gear. so the bolt is to hold the 2 pieces in alignment. You need to use something to hold it, since the gears have springs between the tabs to dampen the crank pulses.
5,758
26,442
I cant say what issues could arrise.
Its there to dampen the crank pulses to the clutch. But the Talon doesn't have the dampened gear, its just a solid gear.
Does this mean the Talon guys won't need to 'bolt' that gear when replacing the clutch?
Talons (and from what ive dug up, 2022 Pioneers) have a solid gear riding on the clutch hub gear.
So yes, the Talon clutch can be done with just the clutch cover off. But id still look at how much debris is in the valve body cover and judge whether the oil tank needs to be removed and cleaned as well.
5,758
26,442
I understand that the valve body cover and oil tank should be removed to check for debris, I just didn't want to be looking for a threaded hole in a split gear that doesn't exist. Thanks for helping us, especially the new SxS guys trying to get up to speed. 👍
Cajun-Abear
Cajun-Abear
49
141
Louisiana
Did you check the screens? There’s one on the valve body and one on the oil pick up.
Can this be taken off with the clutch cover still in place, without draining all of the engine/DCT oil? I'm asking because I didn't clean either screen after a burnt clutch, just oil and both new filters. I'm getting that dreaded clunk between 1st & 2nd and 2nd & 3rd gears that used to not be there, it appears to be getting louder and it is aggravating as hell.
you don’t have to remove the clutch cover. Look on post 94 of this thread. It’s in the valve body with you can access fairly easily
mddconsulting
6
Indiana
I know this is an old post, but THANK YOU CP, acquired my 2016 1000-5 Deluxe last year and started having this problem this year. Clutch Pack is a little more these days but still saved me a lot of money! Only advice I can offer is pay close attention to CP's comment on ensuring the housing fits flush during reassembly. I had about 1/16" gap without tightening and thought I was there....tightened bolts and it sealed. Started it up and let it warm up, put in Drive and immediately died....thought...oh, I forgot to do the clutch re-learn procedure. Did that....same result. Pulled everything back apart and "closely read" CP's instructions and viola case went on flush and everything is wonderful.....Thanks again CP!
THEDUKE_SXS
THEDUKE_SXS
15
29
FL
Hello Everyone
This post is awesome and I am about to do the clutches on mine. I have a 2020 and the garbage dealership did this the first go around and replaced the clutch pack because 1-3-5 were slipping. And as everyone knows it was not covered under warranty even though the machine had less than 100 hours on it and was not abused... yet. Now 2-4-6 are starting to slip with 2 being the worst of them. Sorry if this is redundant or has been mentioned early in this. Is it any different doing 2-4-6 or different part numbers? I am tired of paying the high shop prices and I am going to do it myself after reading this excellent guide. I have started (I know late to the party) manually shifting now to help avoid any more issues. Thanks again and sorry if this was discussed early in this thread, I just want to make sure I am buying the right parts and doing this correctly. Thanks again
Reactions: Lady01 and TripleB
Hello Everyone
Second set is right there not much different. Same part number.
Even’s is pretty uncommon, makes me think something going on. For me it was factory intake boot was allowing dust into the oil. It took out that set too.
THEDUKE_SXS
THEDUKE_SXS
15
29
FL
Thanks!! I don't think mine has been right since I bought it, but the dealership says "nothing else is wrong". I went off on Honda and them when 1-3-5 went out with under 100 hours and they pretty much laughed and said sorry about your luck.
I am starting to wonder if it could be my tires. I have a 6in lift with 31" Interco Boggers. The tires themselves are pretty heavy and maybe? could be a issue? I am going to check everything as best as I can when I do the clutches to eliminate any other problems.
tdhanses
tdhanses
1,044
3,553
Kansas
Do you have a tune? If not I’d consider it as they usually lock the clutch up sooner, I have a Florida Cracker tune but think he doesn’t do it any longer. I wouldn’t doubt those tires are part of the issue and will probably eat up your new clutches as I’d replace both.
THEDUKE_SXS
THEDUKE_SXS
15
29
FL
Do you have a tune? If not I’d consider it as they usually lock the clutch up sooner, I have a Florida Cracker tune but think he doesn’t do it any longer. I wouldn’t doubt those tires are part of the issue.
No tune as of yet. Hoping to do that eventually but not yet.
Reactions: Lady01
Ya tires probably aren’t helping if mixed with heavy mud imo. But there is a large handful of guys doing it without too many issues.
Reactions: Lady01
TripleB
TripleB
21,044
183,268
Caryville, Tennessee
I'd run portals If I lived in Florida.
Reactions: Lady01
Jblanders
6
7
I followed this guide and cannot get the bike to take the relearn! I am stressed to say the least. I am about to take back apart. If it doesn’t work this time it is going to cost me 400 (parts already spent) plus the $2800 from the dealerShip. Any help or thoughts are appreciated!!
Reactions: Lady01
P1K5Dave
P1K5Dave
2,334
8,711
Petoskey, MI
Don't take it back apart until you're absolutely sure you followed the re-learn procedure correctly! It's fussy and needs to be done in a smooth cadence.
Reactions: Lady01
P1K5Dave
P1K5Dave
2,334
8,711
Petoskey, MI
What happens when you try the re-learn? Any responses from your display?
