P1000 Honda Pioneer 1000 Clutch Replacement - A How To Guide!
jonathanalberson
olive branch, MS
great write up, i assume its the same procedures for a 2020 model... less than 400 miles and reverse and 1st have a 2500-3000rpm take off and 3 and 5 red line just to shift.
319,714
Yes same process.
319,714
Try the clutch relearn.
Always worth a shot but being such a large spike in only the one side it sounds like clutch.
Pretty rare in the newer machines especially with the low mileage. How’s oil look? Is the intake boot going away from filter tight to intake? Was there any event while using?
Jbo502
9
KY
Final Step - Posting about this guide!
If you found this guide useful please post and let me know. Not only does that show its usefulness, but it also bumps the post for other members to see and maybe we can save them some time and $$$ too!
If you need further help please post below.
If you see an error, mistake or something out of order or missing please let us know so it can be corrected.
Note: No claim of accuracy is made. The above is a guide based off my personal machine.
Jbo502
9
KY
Excellent write up and documentation. You gave me complete confidence when the time comes.
Thank you!
Reactions: CumminsPusher
Bryan_griggs
7
Lets talk CLUTCH REPLACEMENT!
The 2016 Honda Pioneer 1000 seems to be getting a reputation for having clutch failures and it has been common perception that Honda was taking care of these issues as they come up for all its loyal riders. WRONG!
Lets say if you are stock and haven't drove through a puddle of water 10" or more, then you have a fairly good chance the Honda will approve your replacement. But if you have modified your Pioneer outside "there liking"... well.... You best just read up on the below!
But... Not to worry. For less then $350 and a few hours time you can be back on the trial!
If you can replace an alternator or water pump in your car/truck then you are more then capable of completing this clutch replacement!
Time needed!
  • Stealership = 7 + Hour$$$$$.
  • Novice mechanic = 3-4 hours.
  • Home mechanic = 3 hours.
  • Back yard mechanic = 2 hours.
Parts list.
Oil Filters and Oil.
See: Honda Pioneer 1000 Oil Change Guide!
The below is from a 2016 Honda Pioneer 1000-5 Deluxe.
I hope I get a reply from you on this. I did a clutch replacement the way you said and it worked fine for a week until today. It doesn’t slip at all. It shifts fine when I first take off when it’s cold but then it won’t it’ll get where it won’t shift past 2nd or 3rd.
Bryan_griggs
7
I done the clutch relearn too just to see if it’ll fix it but no change
319,714
Well that’s not a problem I experienced. Does it shift in manual mode? Any codes popping up? Sounds like either temp related or oil pressure
Bryan_griggs
7
Nope couldn’t shift it manual either. No codes. But I went hunting this afternoon and it done like it’s suppose too
kamikaze
kamikaze
74
160
Linden, NC
My 2021 P1K-5 with less than 35hrs/130 miles is in the shop getting a new clutch pack now. Honda Warranty Department refused to cover it because the tires are 1" oversized:rolleyes: and there was some mud in the engine area so now I'm stuck with the $1400 bill, next time I'll do it myself.... But I did give it hell while it lasted and boy was it fun! 😁
Russ989
Russ989
22,565
146,497
Rule number one of mud club is use low with manual shift. 😉
kamikaze
kamikaze
74
160
Linden, NC
My 2021 P1K-5 with less than 35hrs/130 miles is in the shop getting a new clutch pack now. Warranty refused to cover it because the tires are 1" oversized:rolleyes: so now I'm stuck with a $1400 bill, next time I'll do it myself.... But I did give it hell while it lasted! 😁
Always had it in low on muddy trails but shifting manually is annoying. Going to have to get used to doing it
tdhanses
tdhanses
1,044
3,553
Kansas
No warranty?
tdhanses
tdhanses
1,044
3,553
Kansas
Honda isn't covering clutches anymore since the update pretty much fixed the issue.
Sitting in a mud hole reving the engine with the tires not moving will burn a clutch up immediately. Doing the same thing while trying to pull another UTV or whatever will also do it.
So really there isn’t a clutch issue just a machine abuse issue? That is good to know but a clutch can fail, kind of concerning they won’t warranty a clutch on a low hr machine but I see your point, but at least it isn’t too spendy to diy.
Bryan_griggs
7
Bulls*** they shouldn’t have fixed it without talking to you first. I’d been pissed
Bryan_griggs
7
Yea that’s how I burned mine up stuck in the mud with 30” mudder inlaws. Took a 9500 pound winch with a snatch block to get it out
kamikaze
kamikaze
74
160
Linden, NC
They did call and tell me it was the clutch’s and the warranty wouldn’t cover it. But they also said that the machine had “already been disassembled” so I told them to just finish it. Next time, I’ll do it myself.
