Multi Hondasxs.com member safety mods
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,231
Oshkosh, Wi
I finally added harness retainers. No more sliding side to side.
IMG 20190217 130933
T
Thudreem
12
12
USA
I have a p1k-5 and ride with my two little ones (3yr & 5yrs old).
Which 4 point harness would you guys recommend? Do I need a harness bar?
Thx for your help in advance!
Reactions: Mudder and BWAF
Neohio
Neohio
Beast of the East
21,749
93,223
Painesville Ohio
Harness bar is a yes! Without a doubt, for the front seats.
Harnesses themselves is completely dependent on how much you want to spend, and what features are important to you. I would suggest a 5 point harness with a submarine belt, where the lap belt sits in relation to your body is very important. It needs to be low to hold your body when on your side or worse.
T
Thudreem
12
12
USA
Thank you very much!
Any particular harness bar that you like?
Neohio
Neohio
Beast of the East
21,749
93,223
Painesville Ohio
Thanks, I sent @Moses a message to order it up.
You can order it thru his website as well.
I believe he is a forum sponsor and has a discount code for us. I believe also has a military discount if it applies.
T
Thudreem
12
12
USA
Awesome . If anybody can share the discount code, that would be greatly appreciated!
T
Thudreem
12
12
USA
For the 5 point, do you guys normally get a harness with a Cam-Lock? That would probably be easiest to buckle little kids in/out
Neohio
Neohio
Beast of the East
21,749
93,223
Painesville Ohio
I run a camlock style belt. I am currently only running as 4 points. Waiting on my machine to come home so I can mount the submarine belt.
When my belts expire, I plan to order almost the same set, but I'd prefer a pull-up lap belt vs the pull down I currently have.
T
Thudreem
12
12
USA
Can you share some links so I can get an idea? I haven't used a harness for many years now and when I did, it was in a drag car so convenience wasn't all that important at the time.
Neohio
Neohio
Beast of the East
21,749
93,223
Painesville Ohio
Neohio
Neohio
Beast of the East
21,749
93,223
Painesville Ohio
Finally got my machine home. Time to finish some safety items that were pending.
Submarine belt installed!
IMG 20190313 1606545
IMG 20190313 1607359
Harness retainers installed, with zip tie just to keep velcro from failing.
IMG 20190313 1606402
Thank-you @Ragnar406 for the information on harness retainers.
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,231
Oshkosh, Wi
I've kept safety in mind building my 1000-5. I bought one of the first BCF harness bars and added harnesses pretty quick after trail riding with my family. They add both comfort and stability in the front seat. I left all the window nets on and even replaced the clips to keep them in place when they broke so they would keep debris out and body parts in. I didn't realize it until this weekend but having the Alienshade roof also protected us for similar reasons. Additionally, I generally make my passengers wear a helmet and goggles. As it turns out the combination of all these things definitely protected us this weekend.
