P500 How Much Slime?
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I have a gallon on the way. I have used it in my lawn mower, but it will be a first for my UTV. I have a very slow leak in one rear tire, but with multi-floral rose, thorn apple, and locust trees around, figured all 4 tires could use some. The formula on my empty slime bottle says: H X W X 0.12oz = Slime Ounces
Rears: 26 X 12 X 0.12 = 37oz
Front: 26 X 9 X 0.12 = 28oz
So the gallon will be just a couple of oz short for doing all four tires. Do you guys generally, overdo it, under do it, or follow the formula?
I see there is a 45mph warning, so P500 should be good. Never came close with lawnmower. ;)
63,831
I just pump it in. lol.
Think last time I marked it off by 5th's. pumped 1/5 of the gallon into each tire and saved the last 5th for backup.
Reactions: rocmar
rocmar
rocmar
4,741
5,773
4 CORNERS
1/4 gal....each tire.
then carry
Little bottle.....
in Big Black Box
Has never let me down.....
Even a sidewall Rip...taking
6 plugs folded in half...yes aired
up a few times...20+miles to get
home....
My old ass never walked Home
Reactions: Dp5hunter
rocmar
rocmar
4,741
5,773
4 CORNERS
Oh...failed to mention
....I ride through more
catus...first 5 min of
my ride. ..then most of
you...in your lifetime. ...
just saying. .....
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
The only thing that slime ever did for me was show me where the hole was in my tire with green bubbles, rather than stop the leak. Maybe that's not fair, it probably worked a few times and I never knew it. But if you're not riding through cactus I would skip it. Your tire guy will thank you. @Simpleman you need to weight in here!
rocmar
rocmar
4,741
5,773
4 CORNERS
DO not use slime in aluminum wheels it will pit aluminum.
On the inside of wheel. ..
I don't care....where I
ride...slime is just as important
as fuel....
rocmar
rocmar
4,741
5,773
4 CORNERS
Never taken a UTV/ATV
tire....to tire guy....I run slime
when they need replaced...
sell...buy new..which show up....
shipped free...tires mounted
on wheels......Apply to P5
