P1000 I’m confused
DeepPurple
DeepPurple
34
100
Howard’s Ridge, Mo
I’ve been looking at wheels and tires and I’m getting nowhere. I found some wheels I liked and asked to have tires mounted and they said they don’t do that so I cancelled the wheels and started again. I assume any tire shop can mount them even tho they are 14” seeing everything today is 20, 22, 24”. Are all 14” wheels only 7” wide?
Robobrainiac
Robobrainiac
2,566
9,008
Most local tire places should be able to mount them and most online shops most likely won't mount them for you.
14x7 will pretty much fit whatever you want. If you really want something wider here are some I found.
Otherwise you can look at all their 14" wheels
115,818
Like @Robobrainiac said, any wheel and tire shop can mount them. If your doing bead locks you can do it yourself cuz your only slipping one side of the tire over the rim and the other is the bead lock ring thats torqued down. Harbor freight has an inexpensive tire mounting device that works very well. As long as you have a decent compressor and a little bead sealer you can set the bead easy.
60,975
Yep, I've mounted some smaller non-beadlock tires on wheels using the HF tire mounter too. I think they go on sale pretty regularly for around $40. You will need something to mount it to (I mounted mine to an old pallet).
115,818
Yes sir! I mounted mine to a pice of 3/4 OSB i had laying around. Got mine cheep like that too! Has been a very handy tool indeed
60,975
Better yet, make sure your sister marries someone that has a real tire mounting machine and a balancer :D
1626744436528
DeepPurple
DeepPurple
34
100
Howard’s Ridge, Mo
Not done yet, I’ve decided on the Tusk Terrabite 28x10-14 or 29x10-14 which will fit? I do not have a lift on it. I’m getting frustrated finding wheels seems like Honda is not represented very well and everybody must have blue buggies as I can’t find any blue wheels that fit. I have found red ones tho, gimme yer opinion on a blue UTV with red wheels. Or I could get the smoked ones, the wheels are STI HD7 Radiant 14x7
Reactions: Lady01 and Isaiah
Isaiah
Isaiah
2,191
6,964
Altamont TN
28s will fit fine anything above that you will need offset A arms. As for rims I think the smoked color will look better than red imo
