Lil Goat gets some love
322,675
Adjusted shocks for the first time tonight, preloads and dampeners. Not exactly sure what doing on this machine but playing around a bit. She was definitely too soft from factory Looks like about 1.5” raise, with tires should be 2.5 over stock. I’m very interested to see what it did and start playing around some. If it’s not right I’ll get on the Yamaha forum but just don’t enjoy it over there.
Easy way to add preload, no stupid spanner wrench needed, just turn the nut by hand. Literally took 5 min all shocks.
8306FFFE 8729 47EF BD68 F079231AC573
changed out all front ball joints, only one was bad. Super easy on this machine they just tapped in/out light hits from hammer so that was a blessing.
4FFAFF2B C729 4E8D BA48 1F1D79C47C1D
one tie rod was pretty worn so called dealer and picking up both sides tomorrow.
TripleB
TripleB
15,619
140,495
Caryville, Tennessee
I've tried using a spring compressor similar to the one you're using 2 different times with no luck. Always ended up doing the ratchet strap thing. Once on a honda froeman and once on the pioneer.
322,675
Ratchet straps work good I’ve done that as well. What was the problem you saw? Too tight a spring pack?
322,675
Good guy and a wealth of knowledge!
Very good guy. Pretty blunt on things, he tells it how it is and I really appreciate that in someone. He treats you are an individual and figures you out before selling stuff. Rare nowadays.
He mentioned they were trying to get out of doing Yamaha stuff because there isn’t much call for it but he doesn’t want to leave those guys stranded. Like everyone else I suppose he makes his money on Polaris. Said those guys are just open wallets.
322,675
Boy I can’t help but to be a little jealous of work putting into Yami. I see my Pioneer right there and realize the love it needs. It’s been so good too, still fully usable but there’s a growing list. it’s looked the same since way before we got that one, not much changed from the last machine, nearly everything transferred over, it even had the used tires from last one at day 1. It needs its own identity and it’s killing me now a bit.
My daughter’s is more important at this minute but it’s time is coming much sooner then originally planned. I’m just scared of availability on things, already checked on some of the plastics and not looking good.
322,675
Dealer called today and said negative on tie rod ends in time. Had to run 80 miles at lunch to get replacement. Guy said it’s used but doesn’t look so to me. Whatever it takes mode right now.
0A39A860 1E45 41A7 B20B 039C0E7A0281
322,675
Figured I’d post this here as it’s off brand but my family has a new Sxs. After the luck we had with Yami and the availability of aftermarket parts my oldest son pulled trigger on a Rhino. Needs some work but for 1500 can’t complain especially in this economy. He plans on building it up pretty good. Came with 4-seat addition and a brand new big bore kit. Not bad. Had he not bought it I would’ve.
54A0CEA1 50DF 4CB7 A0D3 E6F2D09E6149
013DCB3E 127A 4B9C B9E6 E720FB6F61C1
322,675
Alright got some parts. New fan going in. Been a problem for 3 years, maybe the mud water does effect things lol. Well better late then never. Pretty good for the money with lifetime warranty. Not that it matters because now a 15$ Easy replacement if needed.
432D2321 71F6 45B8 B156 B087CDA54099
Tigermark
Tigermark
Outside looking in.
View attachment 278064View attachment 278063
I would’ve!
322,675
Got servo motor for 4wd yesterday, installed it into the box, greased it all up and works, now have 4wd again. Fan in. Getting some checks off the list.
winch hasn’t had good rope in a bit (hasn’t been issues as Wolverine is light and Pioneer is there if problem) went to spool rope and didn’t work. Found a big crack in the case so tore it apart. It’s was rusted to hell deep in, so much so it didn’t want to come apart.
complete tear down, clean and regrease. Did quick repair on the case and ready to go back in. I figured it’d be scary to go through but not bad at all, I’ll do that with the two on the Pioneer soon as well.
A563F5F3 5807 4352 B248 389215107C7E
EBAA3AF6 3EC0 4152 B32F FE177BF93865
105,595
Looking at the title of the tread I started singing the Love Boat theme song and substituting boat for goat. No Homo Goat Ropo….
322,675
Struggled this time to get the damn knot out of the backside of the winch so after trying punches, drill bits and a few other things I got pissed and poured some lacquer thinner on the rope and set it on fire. After a couple applications she came right out. Not sure that’s the approved method but it worked.
CC360877 54BF 4A53 AF5E 751B3B560DB5
322,675
Front end is all done underneath. New everything. Right side was destroyed but driver side was good like usual on a machine. But driver side everything replaced as well. Yami uses everything the same left/right upper/lower so lots of extra stuff.
winch going grill and bumper on and looking better. Scuffed and did quick rattle can on things to freshen up a bit. Impatiently waiting on plastics. Also clutch stuff. Bent things back around so new stuff will fit.
Hot and miserable working today, kinda at standstill till more parts arrives so it’s quits for the weekend.
C452322C D35B 4570 982F C80948AB8192
