P1000 Low gear gone
Rozik42
5
Pittsburgh pa
So I got a 2016 pioneer 1000 5 delux and it will not go into low gear anytime you try to shift into low gear it just grinds anyone else have this problem I’ve read some other things people are saying it’s a common problem? Anyone have any info would be greatly appreciated thank you
Gabbas
Gabbas
280
700
Humboldt, Iowa
Have you adjusted your shift cables? There's a YouTube video tutorial.
Sent from my Pixel 4 using Tapatalk
Reactions: wrhii
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I wouldn't say its real common but it has happened. I think @Ragnar406 has had it happen to him.
Reactions: wrhii
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I lost Low gear, When i took it in the the "dog ears" had rounded ever so slightly. They claimed that it must have been grinding going into low gear but mine might have done it 1 or 2 times before the cable was adjust and that was in the beginning not 3 years after riding.
Anyway They ended up replacing the gears in the Sub tran and I can say it has appeared to be more solid since. At the time they said "Honda is going to fix it this time" but it was also under extended warranty.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
As far as common I think it has been more common for the Talon but not the pioneer
Reactions: wrhii and JenElio
Rozik42
5
Pittsburgh pa
Thank you. More than likely I’m going to change it myself to save on shop costs. Does anybody know if they have done it there self’s looking for tips
Reactions: wrhii
56,725
I think you'll have more of an issue getting a hold of the parts. I believe there are a few others waiting on parts that have been on backorder for a while due to this Covid nonsense.
Reactions: wrhii
Hondoman
Hondoman
727
1,695
Texas
I'm one of them, but its one talon reverse gear I'm waiting on. I have had the pioneer parts for a few months, been waiting on the last talon part since June 5.
I'm about to say the hell with it and put it all back with 100% pioneer parts....
Reactions: wrhii and Ragnar406
Rozik42
5
Pittsburgh pa
I’ve been seeing a lot of people putting talon reverse gear in there machines. Should I put a talon gear in I know it’s on back order But I also have time to wait or just keep it pioneer gear?
56,725
If you don't mind waiting, I'd install the lower Talon reverse gear.
P1K5Dave
P1K5Dave
2,171
8,115
Petoskey, MI
I had my talon reverse gears on backorder since mid-July, finally got them last week. Shop around, they may be getting caught up.
I just wrote up my sub-trans breakdown in the shop talk section, may help you with the job.
Reactions: Hondoman and wrhii
Hondoman
Hondoman
727
1,695
Texas
Mine came in September 8th and I installed it the following weekend. It made a noticeable difference, not drastic but worth doing especially if your a splitting the case for something else.
